Results 11 to 20 of 80
February 21st, 2012 12:19 PM #11
February 21st, 2012 01:29 PM #13
It's safe to assume that it's time to check the brakes.
In one of the vehicles I use, the brakes make a high pitch noise but the pads are not worn. I think the rotor and pad just got dirty from off-road use.So now, we check at least one side at every oil change.
February 23rd, 2012 09:36 AM #14
Under normal circumstances, you can check and clean your brakes every 10,000kms. If you drive under heavy braking conditions (high speed, mountain roads, heavy automatic vehicle, etc), every service stop, check and clean your brakes.
The pads also have wear indicators which make a consistent high pitch sound whenever you brake once the pad reaches a certain wear point.
March 12th, 2012 09:26 PM #15
Does frequent hard and sudden braking will greatly wear down your brake pads easily?
- Jul 2009
- 3,604
March 12th, 2012 09:32 PM #16Yes.
Also, riding your brakes downhill (even if pressure applied on the pedal is minimal) will wear your brakes.
March 12th, 2012 09:35 PM #17
when your pads are worn out, you push the caliper pistons back inside its bore. this process usually dumps the old, moisture laden and contaminated brake fluid back to the master cylinder. my practice is to clamp the brake hose with a hose pincher to prevent the old fluid to return to the master cylinder and open the bleeder screw as i push the piston back to dump the old moisture laden contaminated fluid out. then, when the piston is seated back, close the bleeder screw and remove the hose pincher. this of course requires replenishing the master cylinder with fresh unadulterated brake fluid
March 15th, 2012 10:18 AM #19
OT:
Just wanted to ask regarding brake hydraulic system. I was reading the manual and it indicates that it has two(2) brakes sub system. Just in case one failed, the other one will function. Question is, spare lang ba ung isang brake system? or the two(2) system is working all the time?
March 15th, 2012 01:45 PM #20
^2 common types of brake system:
1. conventional (front circuit, rear circuit)- usually on front engine, rear wheel driven cars.
2. split diagonal - usually found on front drive, front engined cars
the front brakes is usually the first to bite and the other circuit will also bite under relatively heavy braking. hydraulic control is also utilized by using proportioning valves (load sensing types, etc) so as not to add the braking force by driver, prevent the rear wheels skidding on sudden braking, etc.
i usually check my left front wheel and at the same time, an inspection of the wheel bearing too. if it's good then probably the other brakes are good provided no physical leaks
Yeah, they tried with the styling but one can still see that it is not very Mazda like when...
2022 Mazda BT-50 (3rd Gen)
