Results 1 to 10 of 80
- Jul 2011
- 1,711
February 20th, 2012 12:52 AM #1Mga bossing, ask ko lang po kung paano malalaman na malapit ng maupod ang brake pad at sabay po ba na papalitan para sa apat na gulong or pair (both front or both rear) po ang pagpapalit.
Para po ito sa RAV4 (2004 model ko), kasi nakakarinig ako ng matining na tunog pag nag brake ako pag slow drive or ung nag mamane-obra ako sa garahe. Pero pag drive naman ako sa hi-way same pa din ang pakiramdam ko at kapit pa din ang brakes.
Meron pa bang measurement in term of km para yun ang maging basis sa pag-papalit ng brakes?
Mas ok ba na sa casa ako magpapalit ng brakes or pwede po sa auto shop na lang ako buy at sila na din ang mag papalit, ano pong brand ng brake pad ang recommend po ninyo para sa RAV4 model 2004.
Thanks po..
Tsikot Member Rank 4
- Jun 2006
- 2,605
February 20th, 2012 03:10 PM #2You can have it changed at your suking mechaniko. No need to go to casa. Brake pads are replaced when they wear down. Normally, you remove the wheels and check the thickness of the pads. If its very thin, replace it. Some cars can be checked without removing the wheels.
I prefer original pads. Bendix is also a popular brand. just make sure you replace by pair. So change both front pads at the same time. Rear pads at the same time.
BANNED BANNED BANNED
- Jun 2011
- 125
February 20th, 2012 09:09 PM #3
most american made, canadian made and asian cars have the brake warning tab that makes a high pitch faint noise when the pads wear down to minimum thickness. the warning tabs are usually installed on the leading edge of the inboard brake pad except for toyota previa or estima where the stainless strip warning tab is on the leading edge of the outboard pad. if the pads are thin or contaminated with oil or is physically deformed or had been overheated, they need to be replaced
February 20th, 2012 10:28 PM #4
I use Bendix (Php700-900/pr depending on size).
If you are using the original alloy wheels, take off the wheel and peer into the brake caliper (the chunky thing that's riding on the round brake rotor)
There will usually be a viewing window (opening) on the caliper to help you see:
When the pad wears down, the brake indicator starts contacting the brake rotor and it makes a high pitched sound (braking is still not affected early on). But its time to have the brakes checked before its too late:
New brake pads look really thick (this is the brand I usually use on units when we replace pads):
- Jul 2011
- 1,711
February 20th, 2012 11:45 PM #5Thank you very much Otep, very informative din ung mga pictures. This saturday papalitan ko na ung brakepads ko, un nga lang nde pa ako sure kung front or rear, hehehe pero safe naman siguro na patangal ko lahat ng tyres at pa check ko all brakes. lalo na at nag uulan ngayon.
salamat po ulit
February 21st, 2012 12:19 AM #7
Yes. Thats why a box contains four pads. Para siyang brake ng bike clamping on both sides
February 21st, 2012 09:38 AM #8
Thanks sir. I have read on some threads saying that one indication of a wear down brake pads is the brake fluid level. pag bumaba ang brake fluid level na we-wear down na ang pads. is this information accurate? if it is, how come? what is the relation between the brake fluid and brake pads?
February 21st, 2012 11:11 AM #9
Yep because the caliper piston moves to maintain the distance of the pad with the rotor. And when this happens as the pads wear, the fluid tends to stay on the brake lines instead of the reservoir. When you get new pads, you push the piston back and the fluid returns to its reservoir.
- Jan 2006
- 13
February 21st, 2012 12:14 PM #10Yung sentra ko due na din for brakepad replacement, meron na din ako ng bendix brakepads palitan ko na sana pero nakita ko wala palang shims yung dating brakepads rspec ang brand hindi siguro naibalik nung gumawa o dating may-ari. Nagtanong ako ng shims sa advance pasay meron daw sila set kasama guides etc. hindi pwede shims lang at sabi 900 daw yung set mas mahal pa sa brakepads!
Meron pa kaya makukuhanan ng shims lang o meron kayang surplus nito? Eto yung manipis na stainless sheet na nakapatong sa brakepads dun tumatama yung brake piston, kailangan ata to para di mag-squeal yung brakes.
Toyota Sports 800 (1965 - 1969) behind the man at the start of the video. :nod: I wish car...
2025 Manila International Auto Show
