Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
    Jun 2018
    #21
    Cannot be. May play na kasi due to the busted bearing. That's why most shops won't perform an alignment if something's wrong with your suspension.
    Sent from my SM-A605G using Tapatalk
    Yes, they will first check that your suspension is healthy. If not, they will not perform the alignment. That's SOP.
    looks pricey dyan bro hehehe
    But they're good. Bridgestone Tire Center on Pasong Tamo is also good alternative.
    Sep 2013
    #22
    Thanks SA maliwanag na sagot...
    Pudpod kasi gulong ko SA harap naka negative na Yung gulong NG car na di masyadong ginagamit dito balak ko ipaayos, pinagawa ko na tie rod nun then Sabi ni mekaniko sur basag na wheel hub bearing.
    naalala ko Lang balak ko kasi icamber alignment next week.
    May 2011
    #23
    when your vehicle has handling concerns, first you have your suspension checked for worn out, failed parts (analyze the cause of the part failure)
    then have a prealignment check:
    tire age, pressure, size and condition
    ride height
    wheelbase measured (both sides)
    place the vehicle at curb weight (compensate lost fuel by adding a commensurate weight- 6 pounds per gallon)
    then do the alignment routine:
    rear camber
    rear toe
    thrust angle
    front camber
    caster
    kingpin inclination
    toe out on turns
    front toe
    over center adjustment
    front wheel setback
    steering angle sensor reset if applicable
    anything less is just pretend and incomplete wheel alignment
    Sep 2013
    #24
    Quote Originally Posted by mina_nuka View Post
    ride height
    rear camber
    rear toe
    thrust angle
    front camber
    caster
    kingpin inclination
    toe out on turns
    front toe
    front wheel setback
    Noted sir...[emoji1417]
    Dami [emoji54]
    Jan 2009
    #25
    ride height
    rear camber
    rear toe
    thrust angle
    front camber
    caster
    kingpin inclination
    toe out on turns
    front toe
    front wheel setback
    Who does this?
    May 2011
    #26
    Who does this?
    Me.
    But not for a meager price and not in country
    mahal ng oil change nila sa drive+ looool
    Jan 2009
    #28
    Me.
    Ay sus. Bringing it up is kinda moot then.
    I thought there was a shop that does this here.
    Sep 2013
    #29
    ^ pang formula 1 yatang alignment Yan mga sur [emoji1]
    Ginagamit ko Lang pra bumili ng pandesal car naming extra kya ok na yung simpleng alignment Lang pambawas pudpod SA gulong
    Quote Originally Posted by NiCe2KnowU View Post
    post of the year
Wheel Alignment
