Results 1 to 10 of 36
- May 2005
- 28
June 1st, 2006 02:54 PM #1When buying brand new tires, you will notice that there are red and yellow dots in the sidewall. I presume that the said dots are guides for the location of the "pito" of the tires. But why there are two of them and color coded? Enlightenment please. Thanks.
June 1st, 2006 03:18 PM #2
Well, your correct on that one. The red dot is a uniformity mark. This marks the tyres high point - the spot where the tyre is highest. The yellow dot (sometimes it's a yellow stripe) is the marks heaviest spot on the wheel. It's also known as a 'weight mark'. You aligh this mark to your air valve or PITO.
Them dots you see denote the uniformity and weight of the tyre. Tyre manufacturing is not exactly a precise/perfect process. AFAIK, it's impossible to manufacture a tyre that is perfect in shape, perfect in weight and perfect in dimension. This has to do with how the steel belts inside the tyre are manufactured and how the rubber is moulded. The tyres in the rubber would have a bit of deformation once the rubber has cooled down after manufacturing - and this bit of deformation gives the tyre a wobble. The tyre manufactures then use a process to determine where the wobble is. Once they find highest point of the wobble, they mark it with red. This process also determines where the tyre's heaviest point is. Once they find it, they mark it with yellow.
Hope this helps.
June 1st, 2006 03:59 PM #3
Amazing how often I see brand new cars not having those dots aligned. hehe
Tsikot Member Rank 4
- 1,842
June 1st, 2006 07:50 PM #5
Mukhang di alam ng mga tire installers yung purpose nung dots. From my experience, 1 out of 10 lang ang nag-aalign nung yellow dot sa pito. Yung iba naman sa red dot tinatapat.
June 1st, 2006 08:59 PM #8
if the yellow dot/spot is the heaviest part of the tire, di ba dapat it should be placed at the opposite side against the pito to balance it?
Signature
- Sep 2004
- 132
June 1st, 2006 09:57 PM #9Originally Posted by Automahn
couch potato
- May 2005
- 1,384
June 1st, 2006 11:27 PM #10and this is why bilib ako dito sa forum na ito .. you learn something new everyday ..
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
