Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Nov 2003
    Hi all bakit kaya naging ganito both front tires ko? 15k mileage. Rear tires are ok naman. Okay naman stability sa highway and straight line naman ang takbo. Though di pa na rotate ever so pina rotate ko na Lang. Tire is continental and 2015 date of manufacture.
    where is it made? china?
    Nov 2003
    Germany. Rear tires are okay naman.
    Quote Originally Posted by kenz View Post
    bro if you dont mind, post ka ng pics nung rear tire for comparison.
    Nov 2003
    Eto bro
    Jan 2009
    Looks like dry rot.
    Replace them, whether they can still be claimed through warranty or even if you have to shell out the cash.
    Worse if you can peel off the rubber using just your hands. They’re no good and an accident waiting to happen.
    Are they inflated properly?
    Eto bro
    thanks for sharing bro. for a 3 year old tire, parang sobra naman bilis "masira".
    Looks like dry rot.
    bro what causes dry rot? masyado yata maaga even for a 3 year old tire
    edit: found this online
    TS
    Bet You Didn't Know What Causes Dry Rot in Tires and How to Fix It
    Oct 2003
    Parang ganyan ung front tires ko dati, achilles atr sport. Although heavy user din ako. I just changed all 4 tires to neutons. Never had that problem again.
    I have seen this fairly often with Contis, Michelins and Hankooks even when they were fairly new and with low mileage. If you don't drive hard (i.e track or very rough surfaces) then your case looks like a bad batch to me.
    But generally, this phenomenon is called chunking/pitting and is either caused by: 1) hard driving; or 2) a tire compound or batch defect.
    Jan 2009
    TS
    It could simply be a factory defect... they probably got the chemical makeup of the rubber or how it was processed wrong.
Tires peeling / shredding
