Results 1 to 6 of 6
July 3rd, 2008 09:01 AM #2
imho... around 28 psi is the recommended. but since your tires are quite thin, kaya pa ng 30 psi yan, for you to just protect your rims in case you hit a really bad hole.
July 4th, 2008 04:42 PM #4
Check the Sidewall of your Tyre
If the MAX is 35PSI
I suggest inflate it till 30PSI
(5PSI allowance sa MAX)
July 4th, 2008 10:03 PM #5
July 5th, 2008 02:04 AM #6
Follow the manufacturer recommended tire pressures, even when going with lower profile tires you should stick to the same pressures front and back.
Tires are made to accept a range of manufacturer specified tire pressures so it's vehicle-dependent, not tire size-dependent.
One can only hope.
