Results 1 to 4 of 4
    Aug 2008
    I had my civic repaired at the casa. overhauled ang gearbox, pinalitan yung hose, pinagbayad ako ng almost 19k, nakaka-DALAWANG back jobs na ako (wlang binago sa trabaho, inalign lang ang hose at kung ano pa man), pero nag l leak pa rin ang steering fluid ko, to the point na ubos ang fluid every 2 weeks. Ano po kaya ang problema? Hindi raw rack bar, kung ano man yun. Ano po kaya ang dapat ko paayos?
    May 2007
    Wow 19 grand!
    From where does leak come from? At the same time, look under the engine bay, turn in one direction all the way a till it stops. You will see it leak.
    Check your rack / pinion (long part going all the way across)
    Steering gear(if you do have the above)
    Power steering pump(bolt to the front of engine) or the fluid cannister is crack or the cover is loose.
    Checking power steering leak is not hard to do... Put a cardboard box under your engine overnight and see where does leak come from, then trace it.
    parang hi-way robbery ang nagyari , tapos sasabihin na hindi dun nagtutulo
    wala ka bang propteksiyon ( consideration from casa ) para ituloy nila ang paghahanap ng leak na yun?
    kahit bigyan ka man lang ng break ( sa gastusan)
    agree ako kay v6dreamer straight forward lang naman ang diagnostics dito , mata lang ang kailangan at common sense ang gagamitin ng mga dealer techs
    natural lang na magkamali ang tech na naghandle ng kotse mo pero kung gusto ka nilang i -good time, hindi pagkakamali yan
    puwede mo ba silang tanungin kung bakit nag come up sila na rack and pinion ang sira tapos hindi naman pala yun ?
    or mag visit ka sa independent garage at ipacheck mo lang huwag mo na lang banggitin na galing ka na sa dealer(casa)
    at kung ang findings ay rack and pinion (gear box) or alin man sa ginawa nila for sure under warranty yan ,at least puwede mo nang i contest sa dealer ito , good luck
    Aug 2008
    Naglagay nga ako ng mahabang papel sa ilalim, and the leak was coming from the right side. During my 2nd backjob, pinakita ko pa yun and asked kung san ba talaga galing, yung straightforward na sagot. Instead, they gave me a standard answer na "titingnan" etc.
    Sa repair at 2ng back jobs, alignment lang ang ginawa. Under warranty nga po sa pagkakaalam ko, ang kanilang repair, kaya nga paulit ulit kong dinadala sa kanila. As they are incompetent, gusto ko na nga manghingi ng refund at ipagawa sa iba. Tutal, sobrang hassle naman binibigay nila.
    I think I'll pay a visit to another mechanic and ask for an opinion, baka sakaling mas alam pa ng non-honda affiliated mechanic ang sakit ng honda.
    Thanks V6dreamer and Bambino for the useful advice.
Steering fluid keeps leaking
