Results 1 to 10 of 27
March 12th, 2020 01:43 PM #1
After changing my oil in the casa, they recommended replacing the lower RHS control arm. I asked why, they said they found a tiny hole on one rubber boot. Replacing it would cost me P7800.
My question is, do I really need to change the entire lower arm just for this tiny hole, or are there any other remedies to fix that hole? Maybe refilling the grease and sealing the hole or something. Any experience guys?
image uploader
March 12th, 2020 01:56 PM #2
^sa casa kasi assembly ang palitan.
try mo sa exalta banawe if sa qc area ka
if not, pakita mo nalang sa suspension experts near your area
baka wala pa 1.5k yan including labor
- 54,198
March 12th, 2020 02:08 PM #3what car is that?
first time i see a boot in that area...
is it really a boot?
but if it is really a boot, it does not look fix-able.
replace lang yata.
but i do not know if you can get the boot-only replacement part.
when we were younger,
we would wrap the entire joint in plastic, to prevent dust and water from entering...Last edited by dr. d; March 12th, 2020 at 02:10 PM.
March 12th, 2020 02:23 PM #4
Yes, I’m planning to do that. But I’d like to know if tama ba gagawin nila etc,
Yung sa dulo ng lower arm, sa may gulong na banda. Yung Focus pa rin to. After maayos na ang shock absorber, ito na naman ang problema haha
Baka may ingenious solution yung iba. Hirap kasi papalitan agad yung lower control arm just for that.
- 54,198
March 12th, 2020 02:37 PM #8the rubber boot has no structural function.
the objective of the rubber boot, is to protect the metal parts of the joint from rusting or wearing out faster than it normally does.
if the joint is still good, i.e., no noise or excessive free play, then you can go on using it, as is.
you can replace it when it starts acting up (above).
kasi, my suspicion is, you can not replace that boot. you have to replace the entire assembly.
might as well maximize it, before replacing it.
good luck.
tell us what happens.
and yes. the un-zoomed picture is much better.
in the past,
we have continued using the joint, even if the rubber boot had already torn.
tumatagal naman yung joint, before it starts acting up. something like a year... maybe more...Last edited by dr. d; March 12th, 2020 at 02:52 PM.
- Feb 2014
- 2,694
March 12th, 2020 05:31 PM #9inject grease inside the boot. then patch the hole w/ a bicycle tube patch. get a small and flexible one like Maruni
but that's just delaying the inevitable
March 12th, 2020 06:26 PM #10
I thought I'd address the 2nd elephant in the room.... why is the hub assembly and lower arm soaking in oil? Is the strut/damper leaking as well?
For a 7-seater under 1 million, the Suzuki Ertiga is definitely one of the best options — it’s...
Best car worth 1million and below
