Results 11 to 16 of 16
December 16th, 2009 10:21 AM #11
December 16th, 2009 11:55 AM #12
*Chawap: It'll depend, greatly, on what your specific car is.
What "works" will vary from car to car... It will vary wildly.
I run H&R springs with Tokico adjustables, and the drop was way too low ...even with stock shocks, the drop was way over 2", and I had to use 1.5" lifters in front and 2" lifters in the rear to get the proper three to four finger width clearance for my wheels... and no matter how I set the Tokicos, the ride is just plain harsh over most bumps. On some cars, the H&R will be good, but on my particular car: the Lynx RS, it's a bit much.
Other Lynx owners keep asking me how I got the "perfect" stance... the answer? Tons of experimentation with lifters... :hysterical:
On Sentras, there's a cheap way to lower the front of your B14. Buy replacement shocks for the B13. The B13 has less suspension travel, so the spring perch on the B13 shocks is lower... giving you a 0.5 - 1" drop in front, even with the stock B14 springs... possibly more if you switch to B13 springs.
There are other tricks possible, but it would help if we knew what car you are driving.Last edited by niky; December 16th, 2009 at 12:00 PM.
December 16th, 2009 12:01 PM #13
- Dec 2009
- 21
December 16th, 2009 03:31 PM #14'92 Corolla Gli matic po yun car ko.. ano po ba other possibilities?
around how much po kaya tanabe?
- Dec 2009
- 21
December 16th, 2009 06:17 PM #15any comments for RSR lowering springs? Ideas on how much? salamat po..
May 12th, 2010 01:16 AM #16
Maiba naman ako. Gusto ko sana magpalift ng suspension. Naka outlander kasi ako ngayon pero medyo mababa yung likuran nya kasi may nakakabit na tow hitch which I think is heavy.
San po pwede magpalagay ng lifter dito sa makati?
Ano po ibig sabihin ng bottom out?
Around how much po magpalagay nito?
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
