Results 1 to 4 of 4
Threaded View
July 7th, 2008 03:46 PM #2
dot 3 and dot 4 are compatible, dot 4 can handle higher temperatures. in a dot 3 system you can use dot3 or dot4, but if your system requires dot4, thats all you can use. dot 3 boiling point is 369 degrees where dot 4 is 446 degrees. yes your brake fluid can get that hot. when water and other contaminants get in your fluid it lowers the boiling point even more. i suggest flushing your brake fluid when you do a brake job.
so going back to your question, what is your braking system? DOT3 ba o DOT4? Kung DOT3, use DOT4 na.
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
