Results 1 to 10 of 15
- Apr 2009
- 272
June 23rd, 2017 01:08 PM #1Brake fluid keeps on decreasing despite of no visible leak. My brake pads and drum shoes are all new. What could be the problem?
Corolla 1997 gli 1.6 here.
- Jun 2005
- 3,774
June 23rd, 2017 02:05 PM #2Brake fluid in thr brake master is leaking to the hydrovac (brake booster)
- Apr 2009
- 272
- Jun 2005
- 3,774
June 24th, 2017 12:15 AM #4
- Jun 2011
- 134
June 26th, 2017 05:58 AM #5Check for fluid leak on flooring under the brake pedal.Maybe the fluid leaks inside (pushod connecting the brake pedal and the brake master cylinder).
- May 2011
- 481
June 26th, 2017 02:44 PM #6If your exhaust fumes smell sweet and your spark plugs are glazed, it indeed is leaking brake fluid past the master cylinder to the vacuum brake booster and into the intake manifold.
- Apr 2009
- 272
July 24th, 2017 04:58 PM #7so whats the best solution for this since i cant find any leak between the brake master cylinder and booster.
should i just replace the master cylinder with a new one? replace the booster? or buy a brake repair kit?
- Nov 2008
- 641
July 24th, 2017 05:58 PM #8One way of checking if it leaks through the hydrovac is to pull off the vacuum hose which connects the hydrovac to the intake manifold. If there are presence of oil or fluid, then it is precisely leaking. I would suggest you to replace the entire assembly instead of the repair kit only, as the diaphram in the hydrovac has already been soaked in fluid, which eventually will fail afterwards.
- Apr 2009
- 272
July 24th, 2017 09:55 PM #9
- Jul 2017
- 20
August 23rd, 2017 03:21 AM #10Up ko lang po, having same problem with my nissan cefiro. Tanong ko lang pwede ba gumamit ng ibang hydrovac+master cylinder assembly? Or may parang universal assembly? Sorry for noob question. Thanks!
Don't think about other brands anymore, just go with Amaron. It lasts minimum 5 yrs+ parati, I just...
