Results 11 to 20 of 25
- Jun 2005
- 3,774
December 22nd, 2015 10:27 PM #11O-Sulee sa olx meron yan. Pwede rin rubber lifters para hindi mag bottom out yung shocks.
Yung fender roll, parang tinutupi yung pinaka kanto ng fender na tumatama sa gulong. These usually solve the problem.
Yung pag lubog sa likod usual problem.yan ng toyota sedans.
Cheapest solution is wag mag pasakay sa likod. Hehe
December 22nd, 2015 11:24 PM #12
how about cruven sucat branch? kumusta naman ang honesty and quality of work nila?
may tumutunog kasi everytime nag mamanouvre ako slowly aka maniobra especially kung mag parking sa tight spaces. lumalabas pag pinipihit ko iyong steering wheel left or right
btw, electronic power steering wheel na iyong kotse at wala naman ata problema iyong steering wheel system kasi walang icon umiilaw
medyo madami na din ako napalitan sa pang-ilalim at hindi makita iyong problema
December 23rd, 2015 12:43 AM #13
Okay naman Cruven Sucat but sa akin kasi, mas pabor ako sa replacement parts like 555 or Federal Mogul kesa ipa-press or inject suspension parts sa Cruven. Sa experience ko, after nung warranty nila bumibigay din agad yung repaired parts nila. You get what younpaid for kung baga.
- Aug 2013
- 475
December 23rd, 2015 09:08 AM #14medyo hindi ko gusto alignment nila. sablay sila sa akin, baka sa iba ok naman.
ito bro, highly recommended. JPWheels (may FB page sila). aagahan mo lang kasi medyo mahaba pila araw araw.
Jeremy (09189286705)
Valley1 area, malapit sa Paranaque city hall.
reasonably priced ang mga services, much better kung magpa check/inspect mo muna sakanila (free), tapos bili ka na lang ng parts sa suking auto supply mo tapos sakanila mo ipagawa, may mga readily available din naman na silang suspension parts.
mga clients nila sila Yllana brothers, race teams/cars, mga gawa ni Jojo Howard, etc...
- Dec 2015
- 5
December 24th, 2015 01:35 PM #15
- Apr 2007
- 487
January 27th, 2016 02:02 PM #16Sino ok na underchassis specialist sa Marikina? Yung pwede mo bilhin sa labas yung parts, sa kanila lang yung labor.
January 27th, 2016 02:16 PM #17
imho, suspension specialists vary. what the mechanics do is to diagnose, detect and replace.
you have the option to have that replaced by replacement parts or have them injected/repaired. both ways work. i have tried cruven na din and ok naman ang work nila, except na talagang dapat mag pa align ka pa sa labas (computerized), dahil string method ang gamit nila. as far as I know, the last cruven repair i had was with my getz (bushing lang). ok naman. the last major repair work that they have done with me is with my ex-pizza. replace lahat, pati shocks.... tumagal naman ng 3 years, hanggang mabenta ko na yung oto. but of course, if the margin of costs is really not that high (kung around 10% lang), i would still opt to replace everything with replacement parts, or a combo of both.
- Apr 2007
- 487
January 27th, 2016 06:35 PM #18^^ Gusto ko lang pacheck yung kalampag ng M. Adventure namin, sir. Ramdam na kasi yung lubak sa manibela. Ok lang sa akin na replace kung ano yung may sira, pero ako magsource ng parts ko. Naexperience ko kasi na hinayaan ko na yung shop magpalit ng parts, antaas ng patong nila.
- Mar 2016
- 1
March 10th, 2016 04:47 PM #19Useful Information for repair. Removal and Installation.
Sway Bar End Bushings
http://siberianbushing.com/img/sb/-01-_end.pdf
Sway bar bushings
http://siberianbushing.com/img/sb/e_sb_-01-.pdf
Stabilizer bushing
http://siberianbushing.com/img/sb/e_sb_1-06-135.pdf
Bushings set for the steering rack
http://siberianbushing.com/img/sb/-2..._2010_3000.pdf
http://siberianbushing.com/img/sb/e_sb_1-20-172.pdf
Bushings set for the control arm
http://siberianbushing.com/img/sb/e_sb_3-20-711.pdf
Bushings for the sway bar end links
http://siberianbushing.com/img/sb/e_sb_2.pdf
Shock Absorber Bushings
http://siberianbushing.com/img/sb/-03-.pdf
Leaf Spring Anti Squeak Pad
http://siberianbushing.com/img/sb/-0...Squeak_Pad.pdf
Control arm bushing without outer metal shell
http://siberianbushing.com/img/sb/e_sb_4-06-2792.pdf
http://siberianbushing.com/img/sb/e_...etal_shell.pdf
Control arm bushings with outer metal shell
http://siberianbushing.com/img/sb/14-06-2311.pdf
Control arm bushings with stepped outer metal shell
Bump Stops
http://siberianbushing.com/img/sb/-07-_Bump_Stops.pdf
Bushings without reinforcement
http://siberianbushing.com/img/sb/-0...nforcement.pdf
Leaf Spring Bushings
http://siberianbushing.com/img/sb/-1...g_Bushings.pdf
Torque Rod Bushings
http://siberianbushing.com/img/sb/-11-_torque_rod.pdf
Steering Rack Pad
http://siberianbushing.com/img/sb/-1...g_Rack_Pad.pdf
Universal
http://siberianbushing.com/img/sb/uni.pdf
- May 2016
- 1
May 9th, 2016 02:22 PM #20Sirs, having problems with my suzuki swift 2009. Already replaced rubber bushings and repaired tie rod ends and ball joints pero may tunog pa din pag nadaan sa lubak although minimal n lng. San kaya maganda pa check yung underchasis dto sa paranaque area? Thanks!
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
