Results 11 to 20 of 22
September 27th, 2005 01:23 PM #12
I use Bendix Metal Kings on my Frontier and my bro's Sentra, despite what some claim on rotors being eaten up. So far so good. Ghosthunter also said in another thread that his rotors lasted 5 years before being changed.
Changing rotors is an eventuality with all cars regardless of what pads you use and i'd rather have stronger brakes always. As they say: you can never get enough suspension and brakes.
- Dec 2004
- 98
September 27th, 2005 01:51 PM #13mga guru....innocent question here...
pano mo malalaman na time to change the brake pad na? pag di ba agad kumakagat un brake, does it mean time to change them na?
September 27th, 2005 02:25 PM #14
based on how far you've gone with your pads or if kuripot wait for brake squeal that wont go away, that means the indicator is in contact with the rotor.
September 27th, 2005 03:09 PM #15
Originally Posted by BlueBimmer
September 27th, 2005 07:56 PM #17
blue/white box nga ata ung nabili ko.
hehe. wala kasi akong alam sa mga ganyan, kaya nung may parang squeal na pinatingnan ko na sa mekaniko namin. ayun sabi ung break pad na raw.
September 27th, 2005 10:53 PM #18
Originally Posted by vinj
there is a difference, though. if anyone wants better braking power, upgrade to bigger brakes, not just the pads.
yes, it will take a while before the rotors will be damaged.but metal kings will definitely make it sooner for the vehicle owner to visit his suking machine shop earlier than plannedLast edited by GlennSter; September 27th, 2005 at 10:58 PM.
September 28th, 2005 09:07 AM #19
Point taken dude. ;)
In the end it will boil down to what one would prioritize then. When i drive outtatown the added brake power of the Metal Kings over the stockers is quite evident on the highway and in the mountains; especially since i've adjusted my driving style to using the brakes more over engine braking to help conserve fuel a bit (my first set of pads lasted me over 60,000kms before i decided to changed them since i relied a lot on engine torque).
When i checked before, the cost of a replacement rotor was at the 1k more or less to 2k range depending on the car so it's not that heavy on the pocket given you have to change every 5 years or so.
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 28th, 2005 10:36 AM #20standards do the trick naman. if you like a lot of fast driving naman, even metal kings have a hard time when used hard. for those type of drivers, only upgraded pads such as winmax, project mu, tanabe, etc will do.
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
