Results 91 to 100 of 103
April 14th, 2025 01:39 PM #91
I mostly use shrink-tubes to protect exposed wiring which are under 1-2 inches in length, so a lighter is all I use.
April 17th, 2025 02:07 PM #92
April 18th, 2025 05:14 AM #95
I'm surprised nobody mentioned using an oscilloscope to observe/monitor thebehavior of the wheel speed sensors. Physically moving, unplugging and reinstalling may mask the symptoms temporarily. Wika nga, do not contaminate the evidence. True over time the magnetic tip of the wheel speed sensor picks up ferrous dust or debris that makes the speed sensor "dirty" with garbled signal which in turn "confuses" the EBCM and by default turn the brake warning light ON. In case of sensor tip debris, most of the time, if accessible, can be cleaned and reinstalled, DTCs erased and send the car on it's merry way.
April 18th, 2025 11:13 AM #96
April 18th, 2025 11:28 AM #97
Basic single channel DSO isn't that expensive. Training and the needed equipment is all what it takes. I remember my foreman the 80s who doesn't understand simple electronics and internal combustion engine operating theory. A parts replacer or a mechanic who does not aspire to learn or get training is going to remain a parts replacer. Technology has jumped exponentially. Nobody at repair shop level programmed PCMs in the 80s. Now, it is very common with cars since the year 2000.
- 54,180
April 18th, 2025 11:53 AM #99
A digital storage oscilloscope is not a nice to have but a must have for a reputable technician. Similar to the medical field, a hospital must at least have an X ray machine. You can not advice or recommend to a patient what to do if you are limited on informational or diagnostic equipment.
April 18th, 2025 11:55 AM #100
It's a lot more nuanced than that. Again, this is the PH. One's profession here is nowhere near as appreciated (and compensated more) compared to someone working in more developed countries.
Putting it another way, one's profession and know-how here means nothing to your livelihood if you can't turn a profit from fast turnarounds and volume repairs.
The only value of these highly-skilled repair mechanics who have invested in training, tools and diag instruments is in fault-finding complex and even "impossible" problems. But those situations are far in-between and most mechanics would just lean towards replacing statistically failure-prone parts at the get-go.
As a disclaimer, I don't agree to a parts-cannon approach, but that is the nature of the beast. Besides, bad practice notwithstanding, these mechanics yields good-enough batting averages that has evidently kept them in business.
If you will drive mostly in the metro, go automatic because of the stop-and-go traffic. If mostly...
Toyota Avanza Owners & Discussions [continued]
