Results 11 to 20 of 21
- Nov 2005
- 251
July 10th, 2018 10:45 AM #11Saan mo nabalitaan PMS is 30k??? Normal PMS is not different from other brands. Plus, the current gen Subarus are every 10,000km oil change.
Mahal yung gear oil changes, since 4wd so may front and rear. Last gear oil change from the casa was 11k so still manageable. Aabot ng 20k plus if sasabay mo yung PMS.
Actually mahal na rin parts ng mga bagong Jap cars. Mura yung mga late model other Japs kasi madaming surplus. Sa Subaru no choice but to buy brand new.
My 2013 Forester is out of warranty so I have it serviced sa suking Rapide. They have the proper equipment naman so kaya nila the engine oil and gear oil changes. Proper oils lang need mo kasa special yung oil needed for CVTs and gear oil.
July 10th, 2018 10:50 AM #12
July 10th, 2018 10:59 AM #13
- Nov 2005
- 251
July 10th, 2018 11:01 AM #14
July 10th, 2018 01:18 PM #15
July 10th, 2018 02:51 PM #16
- May 2018
- 157
July 11th, 2018 11:24 AM #17Appreciate all the feedback po! Thanks thanks..
Yung nabasa ko po is 28k yata hehe and it's somewhere in one of the Subaru forums.
I believe medyo matagal po hindi nagamit ang sasakyan..
- Mar 2018
- 62
July 11th, 2018 03:02 PM #18Eto cguro baka mas mahal sa Subaru after warranty compared to other Japanese cars -- replacement for those Steering Responsive Headlights and Bulbs na comes with all TOTL models moving forward. Subaru lang meron nito (yun part) so OEM lang pwede replacement, pero super cool lumilingon headlight pattern kung san ka papunta -- pero syempre, di lang bulb yan may motor din etc.
I have one so did the research bago bilin, pano pag nasira? Lifetime part naman daw ito so never dapat mapundi, pero on the event na mabanga or malasin sa factory defect after warranty hindi ko alam kung covered-- mukhang mahal nasa 350 USD per side yun OEM replacement. So pag meron ka nito mas sulit insurance cguro kahit out of warranty na just in case.
So sa nagtitipid, go for the non-TOTL bowl headlights if meron.
- May 2018
- 157
August 13th, 2018 03:23 PM #19Hello, paAdvise naman po mga master esp. Forester owners.
I'm a newbie and 1st time owner.
May I know what are the basic things to check weekly or monthly?
I know my unit is still under warranty but what are the things I can do on my side?
I am aware to check tire pressure but how often should you do this?
Do I need to refill the coolant or maintain it to max?
Can I fill the radiator with distilled water?
Do I need to buy a washer fluid or water with dishwashing liquid is ok?
Thanks so much!
August 13th, 2018 03:37 PM #20
di naman kailangan na forester...
observe lng the coolant..
tire pressure visual daily...note the sidewall bulge.
windshield washer.. get the mix from ace of you hardly use it. otherwise filtered water lng
2025 BYD Seal 5 Premium Review: Best value hybrid at PHP 1.2M? AutoIndustriya - - - - - - - - -...
BYD Philippines
