Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 111 to 120 of 125
    Feb 2014
    #111
    Although green in color, iba po yata yun FL22 from the usual green coolant like prestone... these new iterations are either extended or super duper long long life variants
    If blue color coolant then use the blue variant..
    i just checked out the ravenol website but it's not clear to me if it's conventional coolant, or OAT
    btw there's no internationally agreed upon color coding on coolants so it's all abrbitrary best to be color blind when choosing coolants
    Sep 2021
    #112
    Quote Originally Posted by Vodka View Post
    btw there's no internationally agreed upon color coding on coolants so it's all arbitrary best to be color blind when choosing coolants
    Yes.
    Gone are the days you can tell the composition of the coolant by its colour. You should not let colour be the only basis for choosing the anti-freeze mixture you want to use. Check out the description on side of the container the coolant comes from. We have said it a million times and we’ll say it again; read the label!
    Source: Which Is The Right Coolant For Your Car? | Coolant Colours Explained
    Ang problem nga lang is (sadyang?) vague ang labels ng ibang manufacturers minsan...
    Toyota Pink (OAT & premixed) & Toyota Red (IAT & needs dilution) are probably similar to Suzuki Blue Super Long Life (premixed) & Suzuki Green (needs dilution).
    Toyota says their "Pink" and "Red" are compatible, but I don't recommend mixing though--> na mention ko lang to set at ease those who accidentally topped (ie. small amount) up their "Pink" w/ "Red" or vice versa and mag panic flushing & replacement. Ma dilute nga lang effectivity nung "Pink".
    Feb 2013
    #113
    Ravenol HJC FL22 meets Subaru requirements for coolant. I wouldn’t use it if it didn’t.
    Any other comments on the Ravenol HJC FL22 confusion here? Is it IAT or OAT? Nakabili na ko ng 2 x 5L bottles.
    yeah it's the typical coolant conundrum. should you honda type1 or type2. toyota red or pink. suzuki green or blue. i always go for the latter coz i don't want the hassle of changing coolants often
    Latter, meaning you use type 2 for Honda cars, pink for Toyota cars, and blue for Suzuki cars?
    Feb 2013
    #114
    Another thing, how do I know if my car's windshield wipers need replacement already? If they do, which brand and model should I be looking for?
    #115
    If you're getting streaks or skipping when it wipes then it probably needs replacing.
    Also just visually inspect the wipers. You can see if the rubber is starting to tear or disintegrate so if it looks like this then maybe replace already even if it's still wiping well. Wouldn't want to suddenly have the blade peel off and scrape your windshield with the bare wiper frame.
    Feb 2013
    #116
    That's what I thought. It was weird though that when my car was new (less than a month), there was streaking after I had my windshield coated with ceramic. I wasn't sure if it was the wiper blade or coating issue, to be honest.
    Jun 2013
    #117
    Quote Originally Posted by kevindd992002 View Post
    If it worked for that one guy maybe it's fine. Personally I wouldn't use it but it's your car. Sabi nga nila "My car, my rules" 😂
    Feb 2013
    #118
    Lol, yeah. Egan101 is very particular with his cars though so he knows this stuff. And based from the articles that were posted here, you should not base your decision on coolant colors. Not saying you're wrong or anything.
    Jun 2013
    #119
    True. Worst that could happen is mixing different coolants that have varying properties would gel up causing the engine to overheat. Minor stuff.
    #120
    I changed my coolant right before I hit 60k km on the odometer. Wala naman issues and never ako nag overheat after over 12k km of use.
    I also used Ravenol HJC FL22 on our ASX. Same thing - no issues whatsoever.
2018 Subaru XV Non-casa PMS
