Results 91 to 100 of 125
- Feb 2013
- 927
February 10th, 2023 05:32 PM #91Yeah, no excuses for this. Hindi ko talaga napansin yung time because of how busy I am at work, life, etc.
* I have a K&N cabin filter so I'll just clean that out
* Is this any good for an air filter? Popular brand? I know you said before that this is the one you're using. Not sure if you still recommend it now.
* Do you know if 2211 does brake cleaning? FusionR does not. They only clean brake pads (not the whole brake system).
* Are the replacement bushings in Velocity Underchassis branded? So after changing the bushings, I have to have the wheels aligned again? Parang nasayang lang yung P700 for alignment na ginawa kanina then, sigh. Any shop recommendation that do laser wheel alignment?
* So draining and refilling the coolant is something that's very easy to do?
* How about replacing the thermostat, no need for now?
February 11th, 2023 12:34 PM #92
As good as K&N products are but I would rather have one that I change every year. Since you have K&N, just clean it regularly (every 6 months).
I use JS Asakashi that I buy from Lazada. I keep air filters and cabin filters ready at home in case I needed to change immediately.
Most auto shops have the skills to clean brakes. You can buy your own brake cleaner fluid (around 200 online). Nearby shops here in Parañaque only charge 800 for cleaning all 4 wheels.
Ain’t it a bitch? You need to check wheel alignment every time you change suspension parts. It is good practice to fix a key issue first so that you will not spend again. I think most major auto shops offer a 2 week warranty for wheel alignment. Maybe you can change your bushings now and have the warranty claimed on the wheel alignment.
Coolant flush - most auto shops can do this. You can even do it on your own but you need an extra hand.
I didn’t have any issues with the temperature monitor so I didn’t bother to replace the thermostat.
- Feb 2013
- 927
February 13th, 2023 03:16 PM #93Yeah, I know that long standing debate on using K&N vs. OEM filters.
Any particular of brake cleaner fluid to buy? Does that P800 charge include the brake cleaner fluid already? If I bring my own brake cleaner fluid, is labor usually cheaper than P800 in shops near you?
Let me ask Whistl3r about the wheel alignment warranty.
February 13th, 2023 04:05 PM #94
- Feb 2013
- 927
February 13th, 2023 04:30 PM #95Got it. Yung engine coolant kailangan na talaga palitan? Sabi kasi ni casa, 50K Km interval nila sa pagpalit ng coolant pero sa manual naman every 220K Km.
Si engine oil kahit sang shop naman ok lang no (like Rapide)? Di ko na kailangan pumunta ng FusionR or 2211 Works. Also, I still have 5.7 liters left of Zic engine oil (leftover yung isang bottle). Will that be enough?
February 13th, 2023 05:10 PM #96
Just to be on the safe side, it’s good practice to change such fluids. Ravenol HJC yung available coolant sa Lazada or Shopee na meets Subaru requirements.
As long as you have engine oil and oil filter, puwede ka pa change oil sa any auto shop. Kung wala ka oil filter, bili ka sa casa or online.
Zic X7 5w30 ba yan? Puwede na yan though Subaru recommends a viscosity of 0w20 for its non turbo engines. Puwede na yan 5L for your FB20 engine. Baka nga sobra pa yan. The turbo FA20 uses 5.5L of oil and normally non turbo engines require less.
- Feb 2013
- 927
February 13th, 2023 06:12 PM #97Ok, yeah, nakita ko na yung Ravenol HJC FL22 sa Lazada. So 8L (6 bottles, 9 liters total) nun, right? Pati ba engine coolant kaya gawin ng kahit sinong auto shop?
Yes, Zic X7 5W30. Eversince, alam ko 5W30 din ginagamit ni Motor Image nung under warranty pa siya. Motul, Shell, Zic (all 5W30's) ang alam kong nagamit na dito. If I remember correctly, 5W30 din nakasulat sa manual. So next time 0w20 na ang bilhin ko?
February 13th, 2023 06:41 PM #98
Get the bigger container ng Ravenol (8L volume), mas mura kalabasan. Kaya gawin ng nga auto shop yan, sabihin mo lang flush ng mabuti. You will only use around 6L but you can keep the remaining to top up once in a while.
Mas common kasi yung 5w30 viscosity. Check your manual, it states 0w20 is recommended but 5w30 can be used. Sa FA20 (turbo), recommended is 5w30 but 5w40 can be used as alternative.
Idemitsu and Amsoil has 0w20 viscosity available. Same price lang sa 5w30 nila. Honda has long been using 0w20 viscosity for its engines. It warms up faster and good for fuel efficiency.
- Feb 2013
- 927
February 13th, 2023 08:09 PM #99RAVENOL HJC Concentrate Protect FL22 | RAVENOL
Walang 8L na variant nung Ravenol sa website nila mismo. Sa Lazada and Shopee naman, puro 1.5L lang ang meron. Merong 5L pero parang hindi legit and mas mahal pa comapred sa 1.5L bottles na lang bilhin. San ka nakabili ng 8L?
Ok, let me check the manual again regarding the viscosity.
February 13th, 2023 08:39 PM #100
I dont think So
Need help choosing a bigger ride for my growing...
