Results 1,171 to 1,180 of 1187
June 29th, 2022 01:27 AM #1171
My 2016 XT’s evaporator and compressor are still good. I did replace the expansion valve and o-rings. When you suspect that no cold air comes out of the aircon, check for leaks or freon content right away.
Since the Forester is always on active AWD, this means all 4 wheels are spinning when running. If changing tires, change all 4 of them. Stock tire size of 225/55/18 is not so common though.
The XT uses a bigger front brake disc rotor and thus its brake pads are not similar to the FB20 Forester. The stock front pads on my XT gave out at 30k km. I suggest you use Akebono pads as replacement.
If buying a used Forester, opt for the XT if possible. You will appreciate the extra power and torque. The 2017-2018 XTs already have steering adaptive headlights.
July 6th, 2022 12:15 PM #1172
Thanks Egan for these tips! I'll likely get the XT if I can find one with good condition and not overpriced.
How about the radiator? I heard some units need to have it replaced after 5 years.
Also, what's your go-to subaru specialist shop? A friend of mine highly recommends FusionR at QC. I prefer a shop that's near to Makati.
July 6th, 2022 01:40 PM #1173
My forester NA is 6 year old with 33k odo. So far I have only replaced orings and expansion valve for the A/C system (P8K] bushing and stabs for the joints (P20K). All casa done. Mas mura sa labas of course.
July 8th, 2022 03:32 PM #1174
Ano nga pala gas fuel type na kailangan sa NA at XT model ng Forester SJ? Should it be high octane like Shell V-Power? 91 octane hindi ata pwede noh?
July 8th, 2022 05:01 PM #1175
95RON yung fuel requirement ng FA20. Motor Image told me I can use up to 97RON. They don’t suggest using higher than 97RON as it will easily foul up the plugs. The stock plugs can last up to 120k km. I am not sure about the FB20 engine but I think it’s common for owners I know to use 95RON.
Eto tip - gas up with UniOil and use your S&R membership card. 95RON comes out cheaper than 91RON with the S&R discount. Yung S&R membership fee mo na 700, bawi yan in 3 full tanks. 5 pesos per liter at 50L means 250 savings each full tank.
Like with dreamur, I had the expansion valve and o-rings replaced last year (5 years old na yung XT ko nun). Together with labor, flush, at freon recharge - inabot ako 5k.
Some Subie owners in Makati go to 2211 Works in Leon Guinto, Manila. Madali lang naman pumunta na lang ng FusionR kung taga Makati ka. Dito sa BF Homes Parañaque, I go to GAT Performance.
No issues with my radiator so far. I did change coolant when I reached 50k km. Ravenol HJC yung nakita ko affordable coolant na meets Subaru requirement. You can buy it in Lazada. Amsoil FS 5w30 gamit ko na engine oil.
Sent from my iPhone using TapatalkLast edited by Egan101; July 8th, 2022 at 05:08 PM.
July 9th, 2022 01:52 PM #1176
Excellent tips Egan, again thank you very much for sharing these [emoji106]
I've been asking around at FB marketplace for 2nd hand 2014 Forester. It's so disappointing that these 2nd hand sellers claiming to be owners (probably bought it from another seller) didn't transfer the LTO registration to their name, and the deed of sale they have are "open", the buyer details are blank.
- Aug 2018
- 25
February 17th, 2024 04:07 PM #1177Reviving this thread. I own a 2016 Subaru FXT. It has logged 40k km already. Of late, I noticed that I need to replace the original tires (225/55R18) due to old age already. I don't plan to change the stock 18" wheels but I'm wondering which of the tire choices below would you go for:
1) 225/60R18
2) 225/65R18
3) 235/55R18
4) 235/60R18
Primary consideration is if it's actually doable without modifying the suspension or lift of the vehicle and if it actually results in a better and comfortable ride as compared to its stock tires. I am undecided whether I should pass the vehicle on to my university son/daughter or whether I should resell this now that I just hit the half century mark and it's freakish ride results to aches and pains on my body way more than I could handle now.
A little extra is what brand of tires would you actually recommend to replace the stock tires.
Thanks in advance.
February 19th, 2024 12:06 AM #1178
February 19th, 2024 12:12 AM #1179
Where do you guys have your Forester's maintenance and servicing done? Ive heard of 2211 and Fusion R but does anyone here have any experiences with these two?
My sister left her Forester here before the pandemic to go abroad and now we've decided to have it fixed while she's finding herself or whatever. Dash has Christmas lights so were considering going to a specialist
February 19th, 2024 11:36 AM #1180
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
