Page 83 of 169 FirstFirst ... 337379808182838485868793133 ... LastLast
Results 821 to 830 of 1687
    Nov 2017
    #821
    I made some quick computations based on lazada price of condura 1.5 hp * P20k and 1.5 hp inverter * P39k, if i use it for 8 hours daily, at P10/kwh, it will take 2 years and 4 months to recover the price difference assuming 30% savings. Will 1.5hp be enough for a 20 sqm room?
    You need to consider energy efficiency nung non inverter after 2 years, you computed on fix rate it will depend on weather conditions. Hot weather will consume more energy than cold one.
    Jan 2016
    #822
    Sir Max, will they have significantly different efficiencies 2 years later assuming both were subjected to the same conditions and operating time? Which one will have a longer life and better eficiency later?
    Nov 2017
    #823
    Window type acu still consume more power than split type. 1hp split type acu * 24/7 almost 2.5-3k monthly bills. Inverter window type 1.5hp *15 hrs/day almost 4-4.5k monthly bills. For me window type acu non inverter on first year maintain its energy efficiency but after that it reduces its efficiency.
    Dec 2007
    #824
    Quote Originally Posted by maxpedition View Post
    Sir parang baligtad ata. Ang comparison ng 1.5hp window type inverter is 2hp split type inverter based on my experience.
    From an existing 1.5hp non-inverter window type, the upgrade would be either a 2hp inverter split type or the same 1.5hp window inverter (same hp).
    Sent from my ASUS_Z012D using Tapatalk
    Nov 2017
    #825
    Quote Originally Posted by Nelson de Leon View Post
    Compare ko lang yung 2 inverter na nagamit ko. 1 hp split type and 1.5 hp n window type
    #826
    Newer inverters have gotten better compared to those from half a decade ago.
    Mar 2004
    #827
    1.5 HP inverter aircon:
    Window = 20-25 square meters
    Split = 15-18 square meters
    You need to use an inverter aircon at least 8 hours daily to be able to have cost benefit ...
    Mar 2004
    #828
    Is this for same sized rooms? ... and same environmental factors? ... like people going in and out ... night time and day time use ...
    The computation might not be accurate. Is the room sealed(doors windows) and insulated(ceiling and walls)? One condo I visited had a main door that was bringing fresh air kuno sa condo. Thats a nightmare for air conditioning systems.
    Jun 2015
    #830
    May appliance stores ba na tumatanggap ng trade in? It might be easier to get rid of our old ac this way than trying to sell it.
Split Type Aircon: Which is best?
