Results 1 to 7 of 7
    Prior to upgrade, my Pldt dsl modem connected to my Linksys router was just like a simple plug and play. Whatever speed my dsl (5mbps) had would also reflect sa Linksys router ko.
    However with the upgrade to Pldt Home Fiber (20-26mbps), the speed of my Linksys router is only less than 3mbps. I guess this is no longer plug and play thing.
    Can anyone here please help me do it right? If possible step by step instructions.... noob here... tia
    My pldt fiber modem is yung white at me apat na antenna
    Apr 2014
    Ntu settings. Although auto is the default.
    Next is check if linksys has qos enabled. If yes, adjust to new subscribed speed.
    Wifi might be on the same freq for the pldt modem/wifi and linksys, thereby causing radio interference.
    Pasensya na noob questions po....
    My pldt fiber is at 192.168.1.1 while my Linksys is at 192.168.2.1, now I want to add an Asus router as access point. What IP address should I use 192.168.3.1 or 192.168.2.2? Again sorry for this noob question
    Feb 2005
    Quote Originally Posted by attyallanlatras View Post
    with my limited knowledge in networking kung sino yung madetect ng asus router mo dun ka kumonek, now kung pareho nya nadedetect kung sino pinaka malapit dun ka kumonek, imho your ip should be supplied by the one to whom you are connected because most of the time naka DHCP yang mga yan based on the ip's you supplied
    ergo all you need to do is supply the ssid/password kung san ka kokonek and that;s it your good to go!
    Sir, meron configuration sa ip address, put it as Automatic (DHCP), the IP address settings and DNS server address setting are set automatically by your router or other access point
    Dec 2009
    ^when cascading several routers, DHCP from the root router (PLDT) wont help
    if the ASUS will be connected to the PLDT then it should be 192.168.1.X or 192.168.1.2 (if this IP address isnt utilized)
    if the ASUS will be connected to the linksys, then it should be 192.168.2.X or 192.168.2.2 (if this IP address isnt utilized)
    Sent from my ASUS Chromebook C202SA using Tapatalk
    Full admin control for PLDT modem/router...
Pldt Fiber Modem and my Linksys router...
