Results 1 to 10 of 14
April 15th, 2014 05:37 PM #1
Anyone experienced this? My original lightning cable charger for my son's ipad mini just gave up on me and had it replaced under warranty. 2-3 weeks waiting time so bumili muna ako ng class A cable. For the first week gumagana naman, but then bigla na lang hindi na nagchcharge yung ipad. Saying something like 'cable is not authentic and may not work properly'. I just don't know kung dahil ba nagupdate ako ng latest version ng OS or what. Similar thing happened to my wife's IP5, nung una gumagana, then after a while same na, not accepting the fake charger. Difference is hindi siya nagupdate.
April 15th, 2014 05:59 PM #2
If you're on iOS 7.x, most third-party cables will simply not work. I say most because, you can still find non-Apple Lightning cables that works, but it's typically far in between.
If your iOS is older than v7, the cable may have simply died.
See here: iOS 7 Killed Off Some Unlicensed Lightning Cables, But Here's A Fix That Might Work For You | Cult of Mac
April 15th, 2014 06:00 PM #3
Try not using your Ipad while charging it. Ilang beses na ako bumili ng 8 pin cable sa CDR King and lagi lang nasisira. Aince then, pinagbawal ko na gamitin yung Ipad habang naka charge.
Posted via Tsikot Mobile App
April 15th, 2014 06:23 PM #4
oj88 - Thanks boss, try ko na din to mamaya
wezz - hahaha, i think this is the culprit kung bakit nasira yung orig cable ko. My son uses it while charging, tapos naka bend na sya pabaliktad.
April 15th, 2014 06:52 PM #5
Tip:
Lagyan niyo ng spring ng ballpen para hindi ma worn-out yung cable laking tipid!
Heres mine
- Oct 2009
- 2,271
April 16th, 2014 06:40 PM #6fake lang talaga ung mga after market na mga usb .maganda talaga ung galing sa unit ,,kapag bumili kaya di baleng gamit na basta siguradong galing sa unit or orig talaga..
April 16th, 2014 08:52 PM #8
April 23rd, 2014 09:05 AM #9
yung sis ko, ilang balik na sa cdrking, under warranty pa yung cable. 2 days lang palpak na.
April 23rd, 2014 10:49 AM #10
Same thing sa akin, nawala ko naman cable ko so bumili ako sa crking works initially pero biglang may lumalabas na not certified and may not work. Bumili ako ng mas mahal na cable sa electronics botique 400 pesos so far ok pa naman. Kapag nasira baka bumili na ako ng orig ulit.
Ilang taon at km run na yang casa stock battery na motolite mo ?
