Results 1 to 10 of 10
    Oct 2008
    any suggestions on what brand to buy for the lpg regulator (for mgas)? also suggestion din po para sa hose, ano brand and klase (rubber o plastic) ?
    thanks
    braided hose naman ang dala dala ng installer..
    Quote Originally Posted by african888 View Post
    thanks
    i use the one the mgas outlet sold in the store. after many years, ok pa siya.
    Sep 2012
    Sa brand wala ka naman halos choice... kung ano meron yun na yun.
    Just make it a habit to check for leaks every month by using soap bubbles to see if there are leaks.
    Sa hose naman go get one with braided steel para hindi agad mayuyupi kung sakaling maipit.
    Sent from my ASUS ZenFone 4 using Tapatalk
    Jul 2013
    same here... any brand for me...
    Pero I remember once (at SG) na yung nag deliver saw that the hose was softer than usual, he checked the serial numbers and told us the hose is too old and must be replaced...
    So I guess just make sure you replace it regularly...
    Oct 2008
    Quote Originally Posted by jodski View Post
    Jodski,
    yong braided ba e yong kulay yellow green na makintab?
    Oct 2008
    ice,
    regularly meaning annually?
    Jul 2013
    ice,
    LPG guy recommended every 5 years.
    thanks
    use the braided rubber hose c/w good regulator. pag medyo pricey, usually better ang quality nya. just don't forget to check for leaks regularly with soapy water solution.
    some gas suppliers do the installation and leak checking upon their delivery.
    Oct 2008
    thanks po sa mga replies
lpg regulator / lpg hose suggestions
