Page 40 of 40 FirstFirst ... 303637383940
Results 391 to 400 of 400
    #391
    ok sakin akari and firefly ang tumagal. ang di tumagal yun mga naunang omni. pero baka bad batch lang.
    kinukuha ko nalang yun mha packs of 3 para makatipid kuno hehehe
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    Feb 2014
    #392
    meron ba tint snobs dito? it really annoys me that led bulbs are either too warm or too cool. why aren't the nice neutral whites more readily available?
    Jan 2008
    #393
    Quote Originally Posted by Vodka View Post
    may mga dual color led lamps na.. pwedeng white, warm tapos pwede white-warm.. mas gusto ko yan. parang mas balanced yung output pag dual color naka on
    Feb 2014
    #394
    interesting... lemme try them... i guess you toggle by on/off? i hope it remembers the last mode
    #395
    it would appear,
    quality control varies,
    even under the same brand...
    ... manufacturing evolution?
    Mar 2021
    #396
    According to reviews, Philips daw pinaka accurate sa color temperature...
    #397
    I had to replace this firefly 28 Watts dahil pundi na.
    Eto pinalit ko, philips 17 Watts. Lumabas na mas maliwanag pa itong 17 Watts vs 28 Watts. Bakit kaya? Hindi porket mataas ang Watts mataas na rin lumens? Is it because philips is better? Or my specs ako na hindi na intindihan?
    #398
    i did notice,
    older leds tended to be not as bright as their equivalent-wattage but newer models.
    #399
    Sa lumens ako tumitingin
    Jan 2009
    #400
    The Philips has a narrower beam... 150°, vs the Firefly's 220°. Another way to put it, the Philips would have more light pointing downward and would be perceived as brighter between the two.
    It also has to do with the efficiency of the LEDs and driver used, as well as how hard the LEDs are driven. Over-driven LEDs tends to be brighter but will have a shorter lifespan.
LED light bulbs vs flourescent light bulbs - electric consumption
