Results 31 to 40 of 41
August 25th, 2015 12:44 PM #31
August 25th, 2015 04:22 PM #32
I tried to access my DVR using my iPhone via LTE and I was able to view the CCTVs. When the iPhone is on wifi with PLDT Fibr (at home), it cannot access the CCTV in the office (also using PLDT Fibr). So is the problem with the PLDT internet?
Signature
- Nov 2009
- 3,507
August 25th, 2015 07:25 PM #33What is your iP address obtained from DHCP?. There is a carrier grade iP that sometimes needs port opening on aggregator router. You may try to check the WAN ip by using traceroute or accessing modem to check the WAN iP.
August 28th, 2015 04:16 PM #36
Try to subscribe to dynDNS first if it's works for you. They have 7 days trial I think.
August 29th, 2015 11:44 PM #37
Turn on the hotspot of your iphone (connected thru LTE), then connect a laptop to your iphone hotspot and execute the following:
ping [external ip of the cctv]
telnet [external ip of the cctv] [port# utilized by the cctv]
A positive response to both commands will tell you that the cctv is reachable from the opposite end and the port is open on all the routers that connects your iphone to the cctv
Try all those commands in your fiber internet and a negative response on the telnet command means that somewhere among the routers of your fiber connection to the cctv that particular port is closed
To determine how many routers your video data need to pass through issue the 'traceroute [external ip#]' commandLast edited by kisshmet; August 30th, 2015 at 12:08 AM.
March 30th, 2016 04:24 PM #38
Last august pa pala ito and I haven't had time to try this. Wala kasi akong laptop, hehe. But I have asked the supplier of my CCTV and they said I need to call PLDT for them to make changes in the settings for my internet connection. Usually problem daw ito sa ISP side.
Anyway, I have another dilema.
In my office, I use PLDT's fibr modem/router as my DHCP server. Pero mukhang hindi kaya ng modem yung dami ng devices connected, lagi sya nagrereset. So I installed a TPLINK router after the modem and used the router as the DHCP server.
PLDT modem --> router --> computers (+other devices)
IP of modem is 192.168.X.X, router is 192.168.Y.Y.
Everything is ok. All my devices can connect to the internet, and all can access the server.
The problem is, I cannot remotely access my CCTV. I have setup port forwarding for both the modem and the router. Ano pa ba ang kelangan i-config?Signature
March 31st, 2016 06:59 PM #40
I think there might be something wrong with your port forwarding rule
Can you share:
- Specific port forwarding rule you created. what port? where is it forwarded?
- IP address of the CCTV
- Port used for accessing CCTV
I would also do some research into the final-design-function performance of carbon fiber hoods...
Carbon fiber hood
