Results 51 to 60 of 164
September 10th, 2016 10:26 PM #51
I'm buying for our company and I insist on AMP USA RJ45 jacks, not those bulk China ones.
Back to topic, I am currently using an Acer Aspire V5-122 with an AMD 1.0~1.4Ghz Quad-Core processor I bought for about 19k some 2-3 years ago. Monitor is an 11.6" IPS multitouch display and comes with 4GB already so I just upgraded the drive to 500GB SSHD and I can multi-task naman. Right now I have 2 Google windows open with around 60 tabs total. :D
Again, whatever unit you came away with, next upgrade after the memory (minimum of 4GB) is the drive. Either you look for a 7200rpm drive or go straight to SSD. I did change my laptop hdd to SSD but since it's only 128GB I find it quite limiting. I just made it into a boot (OS) drive for my PC.
- Aug 2003
- 9,720
September 10th, 2016 10:27 PM #52
Sony sold the VAIO brand sometime in 2014/2015; afaik OK naman reviews. Not sure if the new VAIOs are of the same quality(or available locally for that matter)
Personal experience with 2GB, bitin talaga for Windows; my Dell was unusable out of the box with 2GB. 4GB should be the absolute minimum these days, 8GB preferable.
- Aug 2003
- 9,720
September 10th, 2016 10:32 PM #53
September 10th, 2016 11:02 PM #54
September 10th, 2016 11:37 PM #55
My experience says otherwise on all the points raised.
1. You don't need an i3 unless you do processor intensive tasks (Photoshop, Lightroom, Premiere Pro, games, etc. For basic use, a quad-core Celeron is certainly enough even if you have a hundred tabs open. What you need for better multitasking is RAM.
2. 2GB of RAM will run Win 10, but not optimally. You will experience hiccups with just 2GB. Get at least 4GB of RAM for a smoother experience.
3. I've worked with many Vaios and they aren't any more durable than other laptops. Aside from the ThinkPad, most other laptops have the same so-so durability.
Last tip, if you want to make even your low-end rig much snappier, get an SSD. A 256GB SSD is about 4k nowadays, but it will make your computer much snappier. Bootup will take less than 20 seconds. Opening apps will be almost instantaneous. 256GB is enough for the OS and all your programs, but if you need to download lots of movies, you'll probably have to get an external hard drive to dump all your downloads.
September 11th, 2016 12:25 AM #56
September 11th, 2016 02:59 AM #57
If the TC goes ahead and buys a laptop with just 2 GB RAM, he should confirm if the version of Windows installed is 32-bit or 64-bit. Sometimes, even 4 GB laptops come with 32-bit Windows, making only 3GB (max) usable.
September 11th, 2016 09:31 AM #58
Asus is one of the few that actually make their own laptops ... most of the manufacturers subcontract and rebadge theirs ...
September 11th, 2016 10:20 PM #59
Yes. Among laptops I've used, ASUS is the best. While ASUS is dirt cheap, they are very durable.
I've used Thinkpad, Fujitsu, Dell, ACER. They can't beat the ASUS. Dell is the worst.
September 27th, 2016 11:55 AM #60
Not just the engine. It's literally a D-Max with Mazda styling, but everything mechanical is Isuzu....
2022 Mazda BT-50 (3rd Gen)
