Results 1 to 10 of 20
- Sep 2014
- 57
February 14th, 2019 09:34 AM #1My existing steel gutters have corroded and I am planning to replace them, a contractor recommended to use aluminium gutter, another contractor said aluminium gutter will deteriorate in the weather and suggest to use thicker steel gutter instead.
I understand the both metals will corrode in the air, and it is matter of which will corrode easily, or which will last longer.
I there someone who has used aluminium gutter in his house, and what is your comment on aluminium gutter?
- Nov 2009
- 3,507
February 14th, 2019 10:02 AM #3GI should last 20-30yrs if properly maintained. Alum is hard to work on and will be a challenge on maintenance.
- 54,192
- Nov 2017
- 1,748
February 14th, 2019 12:30 PM #5
- Sep 2014
- 57
February 14th, 2019 01:04 PM #6
February 14th, 2019 02:45 PM #7
Go 304 Stainless, not GI nor aluminum....but don't stop there. It should be thick enough to have all joints TIGwelded not riveted. Leak test the system prior to final install. Do this right one time, the 1st time... you won't need to reprise this repair ever.
Oh, if your gutters are prone to trap leaves, install spout strainers on each & every....Periodic inspection might be needed for this to prevent spout clogs.
If you want zero maintenance, do away with gutters & transfer them to the ground...in form of open trenches. Use plastic kennel pallets(check pic) as cover. They come in 300mm x 600/900mm sizes. Add a layer of gravel on top to hide them.
It has been years since our last fully guttered structure. In cases where they're really necessary, we go selective & only w/ fully TIGwelded 304 Stainless ones.
Hope the tips are helpful.
February 20th, 2019 02:11 PM #8
I had my gutters, sanipa & drain pipes changed just last November. Doc is right that it would look look like an eyesore, but mine turned out OK since the house is painted white & blue gray. If it were painted a darker color, wouldn’t look good. Gutters are actually the headache in house maintenance, so best to go stainless. I also changed my post lights to stainless steel to match the stainless steel gutter.
- Sep 2014
- 57
February 28th, 2019 06:16 AM #9
February 28th, 2019 06:20 AM #10
Isuzu pala makina, at least madali hanapan ng parts.
2022 Mazda BT-50 (3rd Gen)
