Page 6 of 15 FirstFirst ... 2345678910 ... LastLast
Results 51 to 60 of 141
    Jan 2013
    #51
    I'm using a goal zero yeti 400 rated at 400 watts with a goal zero Boulder solar panel 30watts for emergency purposes.
    I exercise the battery by using it to charge my phones and other batteries as well as my laptop.
    #52
    How does that work?
    Thanks for the info.
    got this from website of solar-philippines.
    1. The installed array of PV Panels produces DC Power by gathering energy from sunlight and separating electrons to make a current.
    2. This DC power is then sent to an inverter, which:
    a. matches the exact alternating current and frequency of your building’s grid
    b. and converts the Direct current of the panels to Alternating Current
    3. The power that is converted is then transmitted to the nearest load
    a. If the building consumes more than what the solar produces, the supplement is taken from the original source of power
    b. No switches are necessary with this system. Power usage is done automatically.
    c. Batteries not required
    4. While the solar power is being consumed, the MERALCO meter will move less, as the energy requirement from the electric company is reduced during the day time.
    5. Overall Meralco bill reads a lower demand/consumption – Power bill is therefore reduced.
    6. Excess power produced by Solar and not consumed by grocery is sent out to Meralco and can be credited to the overall bill of the facility through the newly implemented Net-Meteringd process.
    with this set up, we do not have batteries in our system, as the cost of battery is very expensive and i was worried we might not be able to ROI the cost of the battery.
    Jan 2013
    #53
    The benefit of net metering system is reduced electricity bill.
    The benefit of a separate solar system with batteries is that in the event of a blackout, you can still have power in your house. But appliances you can use will depend on the capacity of your battery.
    Aug 2003
    #54
    Meron bang dc/solar version ng surface pump, the type used in homes that fill up a tank? The typical ones i see are pumps na pang irrigation
    Jul 2006
    #55
    I see, that's what I have in mind. Solar power during the day, Meralco power by night.
    2 questions.
    1. How much did the system cost? You can PM me nalang on that, if its ok.
    2. Durability wise, can the panels withstand typhoon winds?
    Mar 2004
    #56
    What's a good Solar Power company in the Philippines?
    #57
    may member tayo na supplier. look at the previous page.
    Apr 2020
    #58
    Quote Originally Posted by slowpoked View Post
    Hi guys!
    We are into solar grid tie system. You can check our website at Home - Eco Solar IndustriesEco Solar Industries | Ecosolar Industries introduces an energy solution utilizing the sun to harness electricity for you.
    Thanks
    Posted via Tsikot Mobile App
    Any post-quarantine promos?
    #59
    Tumatagal ba itong Bosca na nabili ko sa lazada solar outdoor led light panel ?
    #60
    ^ may naka-try na ba ng ganyang security solar lights na nabibili sa online shops? ok ba sila?
    madilim kasi sa likod namin and gusto ko dagdagan ang ilaw. am thinking this is the practical way because summer is approaching fast w/c means sky high electricity bills soon. kahit pa -paano hindi dagdag gastos.
    i tried the garden variety solar lights for the lawn before. may mga tumagal at meron hindi... mas lalo na kapag napag-tripan ng mga aso namin
Alternative Energy/Solar Power for Home Use [Merged]
