Results 1 to 10 of 16
October 8th, 2007 08:42 AM #2
October 8th, 2007 09:01 AM #3
Evaporative Air Cooler:
pro:
-less power needed to operate
-cools a big area effectively
-costs less to buy
con:
-requires venting of air from inside to outside (change air) because of the rise in humidity. Since the system depends on water evaporation, if the air is very humid, the system will not work effectively. It would require installation of an exhaust fan or similar.
-requires periodical water replenishment
-water pad needs to be replaced eventually
-recommended water tank draining if algae is growing inside.
-can only cool 5 degrees from ambient temperature.
AIRCON:
pro:
-can cool a room to a desired temperature (if sized correctly)
-simple maintenance
con:
-consumes more power
-more expensive to buy
October 8th, 2007 11:11 AM #4
went to funeral na gamit lang air cooler, nung madami na tao ang init! sobrang humid nga.
in contrast, sa italianni's sa ATC dati dahil outdoors, very effective and cooling yung air cooler.Last edited by NazQ; October 8th, 2007 at 11:42 AM.
October 8th, 2007 11:40 AM #5
January 6th, 2008 09:53 PM #7
Buhayin ko lang to kasi I am interested in buying one.
Do I have to leave my window open in order for the air cooler to cool my room?iam3739.com
January 6th, 2008 10:30 PM #8
June 13th, 2010 05:17 PM #10
planning to buy one for the living room, what brand would you recommend?
btw lto main office at east ave vehicle inspection office waiting area (open air) does have one. imho its better than industrial electric fans.
Don't think about other brands anymore, just go with Amaron. It lasts minimum 5 yrs+ parati, I just...
