Results 1 to 7 of 7
- Jul 2004
- 14
August 22nd, 2004 10:26 PM #1Do you guys use direct injector cleaner/additive? What brand do you use? Where to buy one? How often to use one? Gas Stations I have gone too is not aware of one.
August 23rd, 2004 11:23 AM #2
Ako po hindi gumagamit nyan. I go to a diesel specialist para ipalinis at ipa-check yung injectors ko. Pero may nakikita ako sa Handyman na injector cleaners. ewan ko lang kung effective.
Tsikot Member Rank 3
- Mar 2003
- 637
August 23rd, 2004 12:09 PM #3magkano ang palinis ng injectors and ito rin ba yung diesel calibration?
August 23rd, 2004 12:31 PM #4
mas thorough ang cleaning kung aalisin ang injectors/noozles. iba po ang calibration sa cleaning although pag calibrate sabay linis na din.
August 23rd, 2004 01:31 PM #5Originally posted by jeff
dun sa RF engine ko calibration at linis less than 1.5K lang gastos ko. nung nagpa-overhaul ako ng injection pump (may leak na kasi pinalitan lang ang gaskets kasi sira na) inabot ako 2.5K kasama na cleaning din at check nozzles.
August 23rd, 2004 11:44 PM #6
I previously use a fuel injector cleaner (Mitsu Fuel System Cleaner bago siya na-phase out) until I realize most diesel fuels already contain detergents and solvents which can clean your injectors and fuel system. (as advertised by Caltex and Shell). Ngayon di na ako gumagamit. Dadag ko na lang ang pambili ng Injector Cleaner sa fuel expenses ko since nagtaas na naman ang diesel by 35 cents just today.
August 24th, 2004 01:34 AM #7
petron diesel booster 44 pesos lang. not bad na yung price. pero not sure sa result. gamit ko every full tank.
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
