Results 1 to 10 of 18
April 13th, 2007 12:07 PM #1
hi! can you guys tell me more about this jeep? ok ba? matibay? reliability? parts? kalawangin ba? malakas sa diesel etc? thanks!
Tsikot Member Rank 3
- Dec 2003
- 546
April 15th, 2007 03:35 PM #2reliability? very reliable. nde pa ako tinirik nito, execpt for a leaking clutch master before, which was easily replaced.
parts. engine and transmission are very easy to find. The engine of the Rocsta is a R2 2.2 Diesel engine, which is the same engine being used by the 1980s Mazda B2200 Pickup and the 2.2 Kia Besta. So engine parts are very easy to find.
It also uses Kia/Mazda parts for brakes, clutch, and transmission. so either u can have a same parts with kia or mazda oem numbers.
Kalawangin? theres rust here and there. but nothing major
the only thing i have to order sa aboard is the balljoints. can seem to find, havent really scouted pa similar looking balljoint sa mga truch and auto supply
April 16th, 2007 10:23 AM #3
hay salamat...akala ko mawawala na lang itong thread hehehe...
anyways...
how about ride comfort naman? where did you buy your rocksta? im considering buying one kasi...or yun korando na wrangler look alike
- Dec 2003
- 546
April 17th, 2007 12:55 AM #4korando looks very old, and engine parts are much harder to find, both for the petrol and diesel versions of it.
Ride? trucks will behave like a truck, but you can put softer shocks if you want to lessen the stiff suspension. In shorts, maalog at matagtag ang rocsta, pwede i replace and shocks with softer ones, pag gusto mo medyo comfortable.
Got mine from a friend.
April 17th, 2007 07:27 AM #5
thanks. parang feroza din pala ito
can you pls post pics of your rocksta?anong year model sya? i am also aware na madami palang modelo yan
mukhang mapapabili ako ng rocksta ah
- Dec 2003
- 546
April 17th, 2007 07:14 PM #6feroza looks nice, pero i have already made up my mind that its indeed a paruza.
my friend who sold me the has a feroza, hehehe lagi sira, something is wrong like di naaubsan ng problema.
two models and rocsta
Rocsta 1 or the 1990 which is a cj-5 wrangler clone. same engine but has a p etrol version watch out ka sa petrol version kasi wala ka parts nito, get the 2.2 R2 version.
may soft top and hard top
Rocsta 2 or R2, the 1996 version, newer look, nde na square fendered, same engine. The front suspension different from the R1 especially sa tie rod and balljoint.
If I were get the Rocsta 2 or R2, or better look at both the pics ng Rocsta 1 and Rocsta 2 and compare then decide.
- Dec 2006
- 36
April 18th, 2007 12:19 PM #7Just been looking at some ads and a 2000 Rocsta Jeep , 4X4 , 2.2L diesel is available for 128K. I keep wondering why the price is a bit low and thinking something must be wrong or bad about the vehicle, and maybe the usual unavailablity of spare parts... Now , seems like its a good deal.
Did some internet search and it does have some potentials .
Thanks for the inputs.
Regards
- Dec 2003
- 546
April 18th, 2007 03:51 PM #8theres not such thing as 2000 rocsta, maybe it was registered here sa LTO natin 2000, kasi imported.
basically it can be a R1 or a R2, and R2 model of rocsta go for 180 to 240k sa subic last time i checked. The R1 or the cj-5 clone go for 150 - 180.
spares are not really a problem, give or tke some p arts that are specific to rocksta. 90% of the parts are shared wid kia and mazda.
My door handle and steering column switch for example are exactly the same with Kia pride LOL
- Dec 2006
- 36
April 18th, 2007 06:01 PM #9Mojo, I came across a thread at 4X4ph concerning the rocsta and I assume that this is the same rocsta that you have. Really an interesting read. I might find myself in that situation wherein I have a choice of a Vitara or that rocsta if it checks out to be a good find. Just need it for a little mild offroading. Too bad , I'm still out of the country so I can't check out the unit.
You mentioned that it'll be hard to source the balljoints and you would be kind enough if you still have the part number for it so I can check if available in my present location. What else are the important parts that are not available in the Phil. ?
Anyway, would you prefer a rocsta over a vitara as a recreational vehicle?
Any suggestion on what to look for / in checking out thr rocsta ?
Thanks again.
- Dec 2006
- 36
April 18th, 2007 06:03 PM #10pitbullz. would you kindly post your feedback on the rocsta if you ever decide to get one and post pictures.
Thanks
Don't think about other brands anymore, just go with Amaron. It lasts minimum 5 yrs+ parati, I just...
