Results 1 to 10 of 10
    Apr 2004
    My father-in-law had his L300 FB (Mitsu 4D56) valve clearance adjusted from 0.11mm to 0.15mm. He claims it made the engine run less noisy than before. Are there any unwanted side-effects?
    hmmm...parang baliktad ata... ang alam ko, iingay makina mo kung naluwagan yung valve clearance... at least that's my experience with a gasoline engine. baka iba sa diesel?
    Feb 2005
    AFAIK, one should follow the recommended valve clearances for the engin from the manufacturer.
    baliktad nga, iingay ang valve pag malaki na valve clearance. baka .15mm to .11mm?
    pag masyado malaki ang valve clearance magkakaron ng hammering effect yung rocker arm sa valve stem, magmu-mushroom yun masisira. faster din ang wear on valve, rocker arm and cam.
    Jan 2004
    what if kung baligtad naman... napa higpit yun adjustment.. what will happen? pwde bang masira yun engine?
    Jan 2003
    mababaluktot ang rocker arm....or either sa valves mo...
    in other words, don't mess with it. hehehe.
    Jun 2005
    e db un po ung inaadjust pag ngpapatune up?
    Dec 2004
    Quote Originally Posted by greenlyt
    Too much may cause loose compression - "tutukod" yung valve stem and hindi na ito magsasara ng tama.
    Jun 2005
    Quote Originally Posted by corbon44
    ano po ung tutukod? kc i was watching as the mechanic was tuning up my engine tas i noticed n parang sobrang sikip ng gawa nya.. i noticed rin after that na tumahimik ung engine.. but parang nwala ung power? tama b naramdaman ko?
adjusting the valve clearance
