Results 1 to 10 of 10
Tsikot Member Rank 3
- Apr 2004
- 663
April 26th, 2005 03:13 PM #1My father-in-law had his L300 FB (Mitsu 4D56) valve clearance adjusted from 0.11mm to 0.15mm. He claims it made the engine run less noisy than before. Are there any unwanted side-effects?
April 26th, 2005 05:15 PM #2
hmmm...parang baliktad ata... ang alam ko, iingay makina mo kung naluwagan yung valve clearance... at least that's my experience with a gasoline engine. baka iba sa diesel?
April 26th, 2005 05:16 PM #3
AFAIK, one should follow the recommended valve clearances for the engin from the manufacturer.
April 26th, 2005 05:22 PM #4
baliktad nga, iingay ang valve pag malaki na valve clearance. baka .15mm to .11mm?
pag masyado malaki ang valve clearance magkakaron ng hammering effect yung rocker arm sa valve stem, magmu-mushroom yun masisira. faster din ang wear on valve, rocker arm and cam.
April 26th, 2005 05:32 PM #5
what if kung baligtad naman... napa higpit yun adjustment.. what will happen? pwde bang masira yun engine?
- Jan 2003
- 46
June 26th, 2005 01:21 PM #9
Originally Posted by greenlyt
August 8th, 2005 11:01 PM #10
Originally Posted by corbon44
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
