Results 31 to 40 of 60
- Aug 2012
- 2,767
February 10th, 2018 09:53 PM #32Refer to your vehicle owner's manual for the safe jacking points. Example, this is from owner's manual of Honda Fit 2018.
The included jack with the vehicle is safe to use for replacing a flat tire. Manufacturers will not include a jack without the correct specification.
Stop jacking up the vehicle as soon as the tire is raised off the ground. It is dangerous to raise the vehicle any higher.
- Aug 2012
- 2,767
February 10th, 2018 10:55 PM #33If rated with same capacity, a bottle jack and a floor jack will lift exactly the same weight. Example, a 2-ton bottle jack and a 2-ton floor jack can lift up to 2 tons weight.
The obvious difference is the body shape and mechanism.
A floor jack provides low profile when collapsed and has wheels, for easy manuevering underneath the vehicle. Because it is bigger, it is not portable and have to stay in your garage.
A bottle jack is smaller in size so portable and can be kept inside your vehicle.
- 54,198
February 11th, 2018 08:29 AM #34i agree.
the alligator jack is safer and easier to use. i have seen small ones now, that can fit inside cars' trunks.
the bottle jack is the usual jack supplied in most cars, as it is cheaper and occupies little space. it also needs some amount of common sense, lest the car fall off its stilt-like configuration.Last edited by dr. d; February 11th, 2018 at 08:38 AM.
February 11th, 2018 09:59 AM #35
Just to add a safety precaution, never get under your car while using your hydraulic jack. You must use a jack stand.
Unfortunately, I can't post pictures for jack stands.
February 11th, 2018 10:04 AM #37
- 54,198
February 11th, 2018 10:17 AM #38
- Aug 2012
- 2,767
February 11th, 2018 10:17 AM #39Our vehicle came with scissor jack. I had used it just once to change a flat tire. It takes some time before you can lift it to the desired height. Hence, I purchased a bottle jack for faster and easier lifting.
- 54,198
February 11th, 2018 10:20 AM #40
One can only hope.
