Results 81 to 90 of 124
December 18th, 2017 04:39 PM #81
Okay, suit yourself. Take care on the road.
Which is more dangerous, bursting a front tire or the rear one? - Updated - Quora
December 18th, 2017 04:51 PM #82
https://m.tirerack.com/tires/tiretec....jsp?techid=52
However, if the front tires have significantly more tread depth than the rear tires, the rear tires will begin to hydroplane and lose traction on wet roads before the fronts. This will cause the vehicle to oversteer (the vehicle will want to spin). Oversteer is far more difficult to control and in addition to the initial distress felt when the rear of the car starts sliding, quickly releasing the gas pedal in an attempt to slow down may actually make it more difficult for the driver to regain control, possibly causing a complete spinout.
2. When replacing only two tires, the new ones go on the front.
The truth: Rear tires provide stability, and without stability, steering or braking on a wet or even damp surface might cause a spin. If you have new tires up front, they will easily disperse water while the half-worn rears will go surfing: The water will literally lift the worn rear tires off the road. If you're in a slight corner or on a crowned road, the car will spin out so fast you won't be able to say, "Oh, fudge!"
There is no "even if" to this one. Whether you own a front-, rear- or all-wheel-drive car, truck, or SUV, the tires with the most tread go on the rear.
CONCLUSION
To give the best possibilities of a vehicle handling safely when fitting new tyres to a vehicle in pairs, it is advisable to fit the new tyres to the rear axle.
If only two tires are being replaced, Michelin generally recommends they be installed on the rear axle in the absence of a tire service professional's recommendation or consumer's preference to the contrary.
December 18th, 2017 04:55 PM #83
As I understand that is if you realky need to replace the tires. But if not yet for replacement. No problem putting a new tire in front.
I could be wrong though.
Sent from my LG-H990 using Tsikot Forums mobile appFasten your seatbelt! Or else...Driven To Thrill!
December 18th, 2017 04:57 PM #84
For Front Wheel drive cars, put the new tires up front. Since those wheels do the driving, braking & steering at the same time
December 18th, 2017 05:05 PM #85
nalipat ko na ung makapal sa harap eh
so papalitan ko nalang ng 2 bago ung likod
tatapon ko na ung 2 manipis
December 18th, 2017 05:44 PM #87
Meron na ba sa inyo na naka Duraplus na more than 80,000 na naitakbo?
Goodyear DuraPlus - GOODYEAR
Sent from my ASUS ZenFone 4 using Tapatalk
December 18th, 2017 05:45 PM #88
December 18th, 2017 05:49 PM #89
December 18th, 2017 05:52 PM #90
What I don't understand is the practice of replacing 2 tires only per time. Sa kumpanya ganyan and I never questioned that practice for as long as palitan nila ako ng gulong.
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
