Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Car: AE100 Corolla XE
    Engine : 2E 1300 (Carb)
    Toyota Shaw recommended to replace the vacuum advancer kasi
    hindi na daw gumagana? sabi namin sa next PMS na lang..tinanung din namin kung sang part ng engine sabi nila
    sa ignition daw..para san ba talaga yun??
    :confused:
    parang sa may distributor yata yan, not sure though
    bump :D
    Jan 2004
    Vacuum advance:sa distributor yan usually my vacumm hose nakakabit. It senses engine load and mechanism advances the engine timing as needed for better power,fuel economy.
    Bihira magloko yan, get a second opinion before replacing.
    Feb 2004
    The Vacuum Advancer is located attached to the side of the distributor, yung round saucer-like thing na may nakakabit na hose leading to the carburettor. It's purpose is to advance the spark timing when the accelerator is pressed, resulting in better torque at low speed/part throttle.
    If you want to be sure, you can test if you really need a new advancer unit. Just unsnap the distributor cap off, remove the carburettor end of the hose, vacuum it with your mouth(not for the delicate person) and see if the plate (inside the distributor) moves every time suction is applied to the advancer. Also, try to hold the vacuum and see if the plate slowly returns by spring pressure. If it does, the advancer diaphragm is leaky and the unit needs to be replaced.
    Thanks for the info ebbfolls. :D
    May 2016
    boss ebbfolls; if i don't repair the advancer; will it damage the engine? thanks
    Quote Originally Posted by rock n rolla View Post
    sir, this thread is 12 years old. and ebbfoils last showed up 11 years ago.
    allow me, instead...
    if the base ignition timing were adjusted correctly for idling... no, it won't hurt the engine.. but it will hurt your pride and your pocketbook.. your ignition timing will be frozen... your car won't accelerate well, and your gas bill will be more than what it should be, were that advancer working.
    some people, however, advance the ignition timing, to make up for its non-functioning advancer. this might cause damage in the long run, as the ignition timing would always be advanced... from idling to high speed.
    pa-ayos mo na po... hindi naman ganon ka-mahal. and surplus advancers are a-plenty.. just make sure it's not leaking.
    May 2016
    Buti nabuhay ulit itong thread. May question ako. kasi kakacheck ko lang din ng mga vacuum tubes ng toyota corolla ko tapos napansin ko yung vacuum advancer walang tubes na nakakabit. Pinasa lang kasi sakin yung kotse kaya wala ako idea sa mga pinaayos na doon. Ok lang po ba ung ganung setup? And any idea kung bakit inalis yun?
    Feb 2009
    on older cars, there are two ignition advance systems in place.
    to compensate for the shortened time where the piston moves, a centrifugal advancer is used to optimize the power stroke pressures.
    to compensate for an increased volume of fuel (increased engine load), a vacuum advancer is used to give ample time to completely burn the increased amount of fuel.
    if the vacuum advancer is not working, it takes a delay until the engine speed catches up and uses the centrifugal advancer but the total advance (centrifugal advance for increased speed plus the vacuum advance for the wider opened throttle plate) will not be reached. fuel consumption will increase and the power output is not at optimum
What's the purpose of a Vacuum advancer?
