Results 1 to 5 of 5
Tsikot Member Rank 3
- Dec 2002
- 636
September 4th, 2004 12:17 AM #1Monark (Cat dealer) offers used oil analysis at affordable rates. They call it their SOS- scheduled oil sampling- available in their lab facility in libis, QC. Contact Cris salvador at tel- 637 9521.
SOS analysis charge:
1) complete testing: Php605 (sos-comp)
wear metals, total base number for engine samples, viscosity either v40 or v100, flash point, water by distillation.
2) complete testing: Php770 (sos-wopc)
same as above with particle count
3) normal testing: Php385 (sos-basc)
wear metals, fuel dilution, water by hotplate
Volume of sample required:
complete test- 250ml
normal test- 100ml
Haven't tried it yet but heard their results are reliable.
Suggest we share test results on this forum, specially on new oil tests, so we have benchmarks for our used oil tests.
February 2nd, 2016 06:55 PM #3
Also interested in this. Anyone else tried getting a UOA quote from SGS Phils? SGS Philippines - Used Oil Analysis: The Secret to Efficient Equipment Monitoring
March 10th, 2016 11:23 AM #4
Below is a recent quotation of a one-time testing of a used oil analysis:
Engine Oil Teting
Water contest - ASTM D6304 - P4,500
Kinematic viscosity * 100*C - ASTM D445 - P2,300
Flash point (PMCC) - ASTM D93 - P1,600
Total base number - ASTM D2896 - P3,000
Metal content - ASTM D6595 - P2,500
Pentane insolubles - ASTM D4055 - P1,800
Total with VAT P17,584
Hindo ko ma-post ung file
March 10th, 2016 12:46 PM #5
Jeez... that's expensive!
Blackstone Labs (in the US nga lang) does the following 'Standard Test' for $28 (approx. P 1,350):
Spectral Exam: D5185 - Establishes the levels of wear metals, silicon, and additives present in the oil. Also checks for coolant.
Flash Point: D92 - Determines the grade of oil.
Insolubles: D96 - Quantifies the percentage of solids present in the oil.
Viscosity: D445 - The flashpoint is the temperature at which the vapors from the oil ignite.
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
