Results 1 to 4 of 4
- Jun 2004
- 4
June 15th, 2004 10:51 AM #1recently replaced 4 new plugs on my carb engine - correct plugs specs based on the service manual. after running for about 50kms saw the plugs' color are not the same:
plugs no. 1 & 3 are very dark, carbonized
plugs no. 2 & 4 light to dark brown. - looks normal
we checked the compression pressure but cylinders are nearly equal above 155psi.
what could possibly be wrong? what should i check next?
is valve clearance related?
thanks in advance for your ideas or suggestions
June 15th, 2004 07:59 PM #2
It could be possible that the valves don't fully close with respect to its clearances. Or valves in 1 & 3 chambers don't fully open to let the air or fuel in.
Have you checked on air and fuel delivery?
Tsikot Member Rank 3
- Dec 2002
- 636
- Jun 2004
- 4
June 16th, 2004 09:29 AM #4Originally posted by Ungas
so i'll have the valve tappets corrected? could this be related: sometimes when i pop the hood, i hear a slight "tst-tsk-tsk" sound under the engine cover.
did a check on the air & fuel delivery. saw the stock paper filter looks clean enough; used carb cleaner spray on the carburetor's mouth (some sludge/dust removed from the choke)
Originally posted by Jackaroo
Also check hi tension cable resistance, your spark may be weak on 1&3.
i'll also look into this. high resistance, weak spark? anyway, i'll compare the wires 1&3 to 2&4, they should be equal right?
i'll get back to this thread once check-ups are made over the weekend. thanks again!Last edited by timberlite; June 16th, 2004 at 09:45 AM.
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
