Results 1 to 5 of 5
- Jun 2004
- 290
June 10th, 2004 07:04 PM #1since i started maintaining our cars. i have always been puzzled by single grade and multigrade oils. when should u use a single grade oil (sae 40) or multigrade oil? my patrol uses 9ltrs of oil so cost is a factor (single grades are cheaper) but i'm concidering other fartors like performance and wear & tear of the engine.
June 10th, 2004 09:07 PM #2
Maybe these past threads could help you:
- Diesel Engine Oil Specification and Price Database
- Diesel Engine Oil for Philippine Climate? Read on... there are some old links in this thread too. :D
April 14th, 2005 11:43 PM #3
The single grade oil retains the same thickness/viscosity whatever the driving temperature is. The double grade one (e.g. 20W-50) obviously has variable thickness. The first number (20) is how thick the oil is when the engine is cold. W stands for winter. The last number (50) is the oil viscosity of a hot motor.
- Jun 2004
- 290
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 19th, 2005 06:41 AM #5get multigrade oils. castrols CRD diesel oil works great and it's not too expensive pa at 100+ per liter.
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
