Results 51 to 60 of 68
- Feb 2005
- 49
July 29th, 2005 12:15 AM #51ako din may problem sa nanginginig na manibela, bago lang car namin, 2004 honda cr-v bought it feb 2005, pinapalit namin tires and wheels during feb din, yung problem is nanginginig na yung manibela pag umabot ng 100kph, nangyari lang to nung around april or may, slightly used lang yung car, every week lang cya ginagamit
July 29th, 2005 03:24 AM #53
alignment issue yan o balancing.. isa lang sa dalawa yan. pacheck nyo at iadjust para macorrect. kung tuloy pa rin ang panginginig e baka maluwag ang gulong nyo.
July 29th, 2005 10:15 AM #54
last weekend, my gf's brother-in-law helped me lower my car's idle speed to around 900 (in-between 4th line & 1K). now i noticed nanginginig manibela when i'm idle in traffic. i can also feel vibrations coming from the engine especially when the a/c compressor turns on. any ideas? tia! --'98 corolla xe
- Feb 2005
- 49
July 29th, 2005 11:03 PM #55alignment issue, balancing? napa align na namin before after mag change ng tires and mags, ndi rin naman nalubakan ng matindi
sa balancing ba? does it mean na ndi pantay tire pressure?
tnx pala sa inyo for the inputs
san kaya maayos mag pacheck around tondo or binondo area?
July 30th, 2005 02:09 PM #56
- Mar 2005
- 33
September 11th, 2005 11:26 PM #57Originally Posted by alwayz_yummy
what should i do? no problem naman sa wheel alignment...thanks in advance!
September 12th, 2005 12:00 AM #58
wheel balancing, nagyari na din kasi yung panginginig sa akin before i thought i was going too fast, then i asked a friend true enought wheel balancing nga kelangan, add tingga lang oks na, but better have teh car check by a credible service center
September 12th, 2005 03:41 PM #59
Originally Posted by mattmatt
September 12th, 2005 04:30 PM #60
as far as I know, basic causes are as follows:
1. nginig when parked & idling - tune up problem.
2. nginig ng converted RHD vehicles from Japan - lack of lateral bracing sa steering shaft.
3. nginig at a certain speed - check wheel balancing first (wheel misalignment do not cause vibration, instead ay pumapaling ang takbo or uneven ang kain sa goma/gulong), if still vibrating check worned ball joint or tie-rod end or pit man arm, etc. (see mechanic at gas station or sa kasa).
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
