Results 1 to 10 of 27
- Mar 2016
- 51
September 10th, 2018 12:25 PM #1Hello mga master maganda umaga po.. may katanungan lang po ako bago ko po dalhin sa pagawaan yong kotse ko para po mayron na po ako idea.. Ito na po katanungan ko sa unang andar po ng kotse ko malambot pa po sya kapag nag-change gear ako sample mula premira to kenta at reverse.. tapos after ko ma-itakbo siguro ng mga 30 minutes or 1 hour ayon na po sya matigas na po mag-change gear lahat tapos kapag nagreverse naman ako sumasabit na sya na parang bang hindi mo inaapakan ang clutch pero nakaapak naman ako sa clutch para magreverse.. yong 12345 naman matigas ilipat kailangan mong pwersahin.. Maraming salamat po sa mga sasagot...Mabuhay po kayo..
September 10th, 2018 12:37 PM #2
How old is the Transmission fluid?
September 10th, 2018 12:39 PM #3
- Mar 2016
- 51
September 10th, 2018 01:56 PM #4
- Mar 2016
- 51
September 10th, 2018 01:59 PM #5
- Apr 2008
- 6,235
September 10th, 2018 02:51 PM #6I think what you have been topping up is the power steering fluid.
Go to your mechanic immediately and ask to have your gear oil changed.
Sent from my SM-G900I using Tapatalk
- Mar 2016
- 51
- Mar 2018
- 263
September 10th, 2018 04:00 PM #8If besides the brake fluid reservoir, clutch fluid yan, although, the same brake fluid naman. Manual Transmission fluid is under the car. If 3 years na yung auto and you havent replaced it, probably the previoius owner, baka di din napalitan. Time to check and change. Normally though, pag mahirap mag change ng gear, its normally the clutch disk or the pressure plate ang defective.
- Mar 2016
- 51
September 10th, 2018 04:32 PM #9
- Mar 2016
- 51
September 10th, 2018 04:45 PM #10
Agree with you there. Nicely put.
2022 Mazda BT-50 (3rd Gen)
