Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Mar 2016
    Hello mga master maganda umaga po.. may katanungan lang po ako bago ko po dalhin sa pagawaan yong kotse ko para po mayron na po ako idea.. Ito na po katanungan ko sa unang andar po ng kotse ko malambot pa po sya kapag nag-change gear ako sample mula premira to kenta at reverse.. tapos after ko ma-itakbo siguro ng mga 30 minutes or 1 hour ayon na po sya matigas na po mag-change gear lahat tapos kapag nagreverse naman ako sumasabit na sya na parang bang hindi mo inaapakan ang clutch pero nakaapak naman ako sa clutch para magreverse.. yong 12345 naman matigas ilipat kailangan mong pwersahin.. Maraming salamat po sa mga sasagot...Mabuhay po kayo..
    How old is the Transmission fluid?
    Feb 2009
    Quote Originally Posted by mjamolin24 View Post
    Temperature affected.
    Try changing the gear oil to the recommended type.
    What vehicle is this?
    Identify your car and if you can find the door sticker tag, you can find what transmission/transaxle type your car was equipped with
    Mar 2016
    Cnsya po newbie pa ako now ko lang naencounter itong problem pero 3 years na po sa akin yong car.. Honda civic 93 po kotse..
    Mar 2016
    3 years na po sa akin yong car diko po alam.. cnsya na po. iba pa po ba yong fluid don sa hood sinasalinan ko lang kapag kaunti na.. katabi sya ng brake fluid reservoir.
    Apr 2008
    I think what you have been topping up is the power steering fluid.
    Go to your mechanic immediately and ask to have your gear oil changed.
    Sent from my SM-G900I using Tapatalk
    Mar 2016
    Quote Originally Posted by GTi View Post
    ok sir may idea na po.. salamat po sir.
    Mar 2018
    If besides the brake fluid reservoir, clutch fluid yan, although, the same brake fluid naman. Manual Transmission fluid is under the car. If 3 years na yung auto and you havent replaced it, probably the previoius owner, baka di din napalitan. Time to check and change. Normally though, pag mahirap mag change ng gear, its normally the clutch disk or the pressure plate ang defective.
    Mar 2016
    Quote Originally Posted by RavenBlack View Post
    Ok po maraming salamat po Sir.. mabuhay po kayo..
    Mar 2016
    Sir tanong lang po.. may idea po kayo magkano clutch disk saka pressure plate kung sakali yun ang sira.. salamat po.
Matigas mag-change gear
