Results 1 to 10 of 27
February 8th, 2006 04:44 PM #1
I'm going to have the underchassis repaired. Here is the quotation for parts. Though it's still not certain whether all the parts on the list will be used, the parts store still listed them down 'just in case'.
Upper balljoint 650x2
Lower balljoint 850x2
Pitman arm 1200x1
Idler arm 1350x1
Tie rod 450x2
Shocks (KYB Gas non-adjustable in case the adjustable ones are shot already) 1100x4
Ok na ba ang prices na ito? Pareho po ba ang pang-ilalim ng GEN II sa GEN II.5? I'm pretty sure they are but I just want confirmation. Wala kasi yung unit dito ngayon.
How much do I expect to pay in labor (shadetree mechanic)?
How much does it cost to realign afterwards?
Salamat po
- Jan 2003
- 62
February 8th, 2006 05:04 PM #2Try to ask ZEE at Aurora Blvd. Was supposed to have my shocks refilled there but ok pa at the time so those parts you listed lang talaga ginawa. Rey is there Paj expert. He's their all-around "consultant."
Btw, for sure palit ka bushings din nyan.
February 8th, 2006 05:10 PM #3
Oteps, there are four tie rods to a Pajero
I think most suspension parts are the same for the 2 and 2.5. Pansin ko lang na iba is the stab bar and stab bar links.
Alignment sa servitek mga 1200-1500 kasi definitely may camber correction involved.
Make sure you go to a friendly mechanic para one-time-take-all ang price kasi kung sa regular mechanic/casa, per part ang singil ng labor.
Meron ako alam kaya lang dito sa pateros.... medyo malayo.
Good as new na yan pagkatapos.
BTW, naka Gen2.5 ka na pala! Congrats!
February 8th, 2006 05:12 PM #4
It's the office vehicle and it would be better to have any faulty parts replaced as opposed to 'repaired'.
I also do not want to subject the stock adjustable shocks to disassembly if it will lose adjustability anyway. If the shocks are found faulty, I will just take them home in a box.
My '96 daily driver has had no bushings replaced since we got it. Wala naman problema sa suspension (except for the rear sway bar bushings). Anong bushings ba iyang 'sure' na papalitan? Thanks. The FM is a 2001 model if I'm not mistaken.
February 8th, 2006 05:15 PM #5
PK,
Nilista lang naman ang Tierods (mali pa naisulat sa listahan!). Magkaiba kasi yung mechanic at yung parts store.
Btw, kay Mang Dick (yung in-house ni GlennSter) ko sana ipapagawa once the budget is approved. I guess he's friendly enough. hehe.
February 8th, 2006 05:22 PM #6
Ayus! Nakakatawa kasi sa Motorix, parang casa na rin sumingil kaya di na ako dun nagpapagawa. Imagine, separate ang singil ng tie rod dis/assembly sa pitman and idler disassembly/assembly. Eh kung iisipin mo, kelangan mo naman tanggalin yung tie rods to get to the arms?! (And so on)
As if naman ikakabit nila uli yung tie rods before nila babaklasin yung pitman/idler.
I'll go through the same process within the year din siguro. Mabilis makasira ng tie rods ang 20"-45 series hehe.
Oh well....
February 8th, 2006 06:48 PM #7
Originally Posted by OTEP
suggest ko lang po go for orig 555 brand. hwag dre**
mas matibay 555
shocks around 800 lang yata... kyb gas...
February 8th, 2006 10:16 PM #8
Sir banaweonline,
Three Five (555) po ang gamit ko. I don't use Dreco for the underchassis bits.Medyo takot ako dun.
February 8th, 2006 11:21 PM #9
otep,
naask mo sa a1 motorcraft? baka masmura sila? not sure....is there such a thing as kyb shocks for 2inlift na pajero?
February 8th, 2006 11:35 PM #10
Mas mahal ang parts sa Motorcraft. Ganun naman ata talaga kung sa talyer ka bibili instead of the parts store. Convenience kasi.
May mga longer na KYB, ewan ko lang if meron locally.
We are planning to buy an SPresso next month. But there are rumors about it's continued production....
Suzuki Philippines
