Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jan 2008
    Fellows, the fluid in clutch master turned black. What's the cause and what should i do, may sira ba somewhere?
    May 2007
    Flush it. Replace w/ new fluid.
    Jan 2008
    Quote Originally Posted by v6dreamer View Post
    is this normal? fluid was still fresh last december 2007.
    that's pretty much normal because of that rubber thingy dun sa dulo ng piston sa loob ng cylinder, as long as there's no leak, that's okay
    Nov 2007
    yes tama si V6 flush it with new fluid, mas okay kung all wheels ka magflush ng fluid para mas malinis ang linya ng brake mo. No 1 cause ng maduming fluid ay ang mga naipon na dirt sa may wheel cylinder.
    Aug 2003
    ^ im, by far, not an expert pero.... di ba hiwalay ang fluid reservoir ng clutch master and brake master cylinder?
    ontopic, wala naman kaso yan pangingitim ng fluid, cause nga lang yan nung rubber sa loob ng assembly. pag walang leak or di pa lumulusot yung clutch sa shifting, ok pa yan.
    Aug 2003
    ~ weird, double post sa single click
    Nov 2003
    normal lang for it to turn dark. if it keeps happening fast though that might be a sign that the master is about to go so keep on observing it.
    Oct 2007
    The fluid of a certain master turns chocolate brown, gets small in amount and becomes more viscous. Same problem you think?
    I assume it's the clutch master because it's near the brake fluid vessel, takes DOT 3 fluid only. It' s in the corner, driver's side. Inside the vessel is a rounded, black rubber like float. Corolla. Do you think so?
    So how do you flush it?
    Thank you. :flush::mop1:
    Jun 2008
    hi.. its an internal bleeding for the clutch master or the secondary master... the cylinder wall is worn out or the wheel cap due to wear and tear.. so flushing the fluid would do no good at all.. so better to replace the part to a new one..
    further usage of worn out hydraulic master and cylinders will do no good...
Fluid sa clutch master turns black
