Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Quote Originally Posted by bebe_vega View Post
    Madami po ba naging requirements na kailangan kakarenew lang po kasi ng rehistro ng car last august 2024. Nung binili namin dun sa seller di namin napansin yung chasis number. Wala din po kasi kami balak ipalipat sa name namin yung CR.
    it seems to be an honest mistake.
    even the stencil boys and acid etchers, whose job it is to spot these, appear to have missed it.
    with luck, LTO will make the corrections without much ado.
    but why do you not wish to transfer ownership to your name via CR ?
    Oct 2024
    Quote Originally Posted by never424 View Post
    Thanks Guys for all the answers.... I already checked it with the seller. It seems clerical error nga lang... na paayos ko na sya... sa records ng LTO. Thanks ulit...
    yung issue din sakin kulang ng first letter yung chasis #. Ano kaya process nito mga sir and ano po requirements. salamat po sa makakasagot
    Quote Originally Posted by gsecuya View Post
    bring the car to the lto and have them get a look-see. bring your papeles also.
    if the typo is reasonable naman, they can make it happen.
    these errors happen more often than we think.
    the act of inspecting the serial numbers is usually a difficult body position... errors are likely to happen... ... exchanging similar-looking characters... miss stenciling the first character or the last character... even wrong typing sa makinilya!
    yes, there is the omnipresent admonition, "paki-check nyo po.." , but in the heat of the excitement of owning the car... we forget our senses.
    Dec 2024
    Hello There!!
    I am new to the forum and would like to get assistance on my concern. I am currently purchasing a car from a direct seller and is in the process of securing documents for this. While receiving the original OR / CR from the seller to execute the transfer of ownership, I noticed that there was a slight discrepancy on the chassis number vs. the stencil copy of the vehicle. Can i get advice on how to correct this?
    Number 2 of posts and replies
    Hello There!!
    this original post is 14 years old.
    1. if you develop cold feet because of the potential problem, and there is really no compelling reason for you to like that car, then back away, sir.
    2. you might also ask the seller, who i assume is the name on the CR, to have lto correct it.
    3. but if the error is reasonable naman, you can probably effect the correction when transfering ownership to you. ask lto if they can do it, po. show them the discrepancy, and inquire if they will correct the error.
Chassis Number Problem
