Results 1 to 10 of 10
April 19th, 2008 12:34 AM #1
nabasag po yung dash sa may parteng kambyo dun sa may adaptor ng lighter. san ba makakakuha nung part ng dash na yun at bagong adaptor para sa lighter? ang hirap po e. 97 cefiro nga po pala yung car
tia
April 24th, 2008 07:56 PM #3
hi bro!
we have the same problem. its called a shifter bezel. mine has cracks na. i was quoted 1500 by kelseat in banawe last december. the job will take around 7days
i just don't know if kelseat is still operating because the last time i went there, i was told that they are under new management and won't accept job order for the time being.
April 25th, 2008 04:21 AM #4
sana gumagawa pa sila kasi cracked na. or sana merong oem. pag pumunta akong banawe magtatanong tanong ako
April 26th, 2008 12:04 AM #6
ang mahal pala. may nakita akong wood panel yung itsura nya sa ace kaso pang innova e. yung isang part lang na yun, yung ganun kaliit. pero mura na yung 1.5k kesa sa 7k
May 6th, 2008 12:41 AM #7
sana makahanap ako sa banawe nung wood panel sa shifter na yun. san ba yung kelseat?
May 6th, 2008 09:05 AM #8
bro,
good luck in finding one at banawe. hehe. post mo dito if you did. anway kelseat is in banawe corner n. roxas. not sure talaga if they're still open.
alternatively pala, search mo sa ebaymotors: maxima shifter bezel. meron din don wood panel/carbon fiber dash kit for maxima/cefiro.
The subject vehicle in question is a typical four channel ABS/traction controlled system that uses...
ABS and Handbrake Lights Both On
