Results 1 to 10 of 12
- Nov 2003
- 190
December 28th, 2004 08:06 PM #1Is it okay to apply belt dressing to the various belts of the engine on a regular basis, say every three months? I ask because I clean/detail the engine quite regularly, and I can't help but feel that the belts are being left out of the cleaning/maintenance process. What's more, won't that keep the belts supple?
So, should I on a regular basis?
December 28th, 2004 09:26 PM #2
oks lang yan pre, pero baka sobra yung every 3 months. gumagamit din kami nyan dito sa rig pero every 6 months lang saka pag dry ang rubber para hindi maging brittle(summer time). kung linis lang ang gusto mo, pwede naman linisin ang belts ng soap and water.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 30th, 2004 11:15 AM #4
btw how do u apply the belt dressing? just spray on an exposed part of the belt and let it run?
SiRaNeko
- Jan 2003
- 973
- Nov 2003
- 190
December 31st, 2004 04:55 PM #6Well, if you do have a belt that squeals, applying some belt dressing will remove the noise instantaneously. Of course, some people may frown on this practice because it is more cosmetic for the purpose than anything. If the belt squeals, then it is too loose or too tight. Ergo, the correct solution would be to tighten or loosen the belt.
On the other hand, I was thinking that application of the belt dressing as part of routine maintenance could prolong the life of the belt or at least make it more supple. But I really don't know if it will. It was just a thought. After all, we do apply dressing on the rubber hoses of our engines as part of maintenance/detailing, don't we? So, why not do the same for the belts?
BlueBimmer, you spray the dressing on the surface of the belt that has contact with the pulley. Actually, the instructions are on the can's label.
December 31st, 2004 05:04 PM #7
san po kayo bumibili ng belt dressing?
anong brand yung ginagamit nyo?
thanks!
December 31st, 2004 05:27 PM #8
belt dressing is used for preventing the rubber to become brittle due to high humidity and/or high temperatures. it prolongs the life of the belt, it is not just for cosmetics. read the label.
it is not for removing squeeks. when a belt squeeks, it means only one thing -- the belt is slipping on the pulley due to incorrect belt tension. the cure is to tighten the belt to the recommended tension. although applying belt dressing will temporarily remove the squeeks, it does not solve the situation. soap does the same trick, don't ask me why but it prevents the belt from slipping. when the dressing (or soap) wears off it will squeek again.
SiRaNeko
- Jan 2003
- 973
January 1st, 2005 10:47 AM #9ignorant question lang po.
do you spray with the engine running? para umiikot yung belt and malagyan lahat?
o you remove the belt apply the spray?
January 1st, 2005 11:21 AM #10
kahit ano pwede, pero hassle kung tanggalin mo pa ang belt. here on the rig we just run the equipment then spray on both sides (inside and out). mag-slip sya pag wet pero it takes only a few seconds to dry. konti lang spray mo, pag sobra e dudumi naman at mag-stick ang dust.
One can only hope.
