Results 11 to 16 of 16
- Mar 2010
- 2,273
January 27th, 2014 05:35 PM #11
March 6th, 2014 10:20 AM #12
Adventure din sakin, first gen.
May tunog "bakal" sa ilalim - which is ipapa-check and ayos ko next.
hindi kaya propeller shaft?
- Jul 2011
- 1,711
March 6th, 2014 10:37 AM #13
1. Punta ka sa shop na meron lifter
2. Habang nakasakay ang driver, i-pa lift mo ung car mo
3. While the engine is running ikutan nyo sa ilalim kung meron tumutunog
4. Shift to gear, para umikot ang gulong, ikutan nyo ulit para marinig ung source ng tunog
Pag na identify nyo na ung area/source ng tunog mas malapit sa katotohanan ang repair estimate.
March 9th, 2014 05:16 PM #14
March 13th, 2014 09:58 AM #15
kung minsan, sa pagbabago ng anggulo ng prop shaft at transmission (ayon sa road condition at load) e sumasayad yung dust cap (sa may rear ng tranny) sa propeller shaft.
kung u-joint, malalaman mo agad kapag inuga mo yung prop shaft (wag mo paandarin ha). gawin mo ijack mo isang rear wheel tapos punta ka sa ilalim ng sasakyan (kung gusto mo marumihan) at icheck mo kung matindi ang play ng prop shaft...pero be safe! wag ka umasa sa jack. gumamit ka ng jackstand o kahit anong matibay na bagay na pagpapatungan ng sasakyan mo.
running a high gear at low rpm ay iwasan mo rin. this way you are lugging the engine atsaka yung drive train.
at stand still with engine running, apakan mo clutch. kung umingay ng husto, release bearing. pero kahit hindi mo apakan, pilot (ball) bearing. yun ay assuming no other loose connection sa exhaust system, etc.
March 13th, 2014 10:03 AM #16
Sir, what is your basis in saying that the battery system of Sealion 6 is old? I have asked the BYD...
BYD Sealion 6 DM-i
