Results 171 to 180 of 869
November 7th, 2014 07:36 PM #171
November 7th, 2014 08:41 PM #172
Claimed FC figures are usually achieved during standardized controlled tests. I never believe the trip computer FC. I get much more accurate measurements using the fuel tank top off method, but still I'm under no illusion that in real world situations I'll be getting anywhere near the published FC.
We should factor in not just the FC but the purchase and running costs as well. Today's turbodiesels are very heavy on maintenance. They require more frequent filter and fluid changes, a lot more oil (more expensive oil as well), expensive filters, and parts are expensive (EGR valve, cat, turbo, fuel pump, injectors, etc). It's either you pay at the pump with gassers or at the shop with oilers.
November 7th, 2014 08:46 PM #173
- Mar 2004
- 98
November 7th, 2014 10:22 PM #174I drove a 4x2 2.0L X-trail at NLEX last week. I tried to keep the speed to just 80km/h & just going above 100 km/h to overtake and the computer yielded 16 Km/L.
November 8th, 2014 02:20 AM #175
November 8th, 2014 04:48 AM #176
November 8th, 2014 03:21 PM #177
November 10th, 2014 11:19 PM #178
Thank you sir, but with anything, YMMV. If you know someone who brings in parts or if you sell your car early on before the major parts need replacing you might save a bit on diesel. I'm just shocked at the price of modern diesel parts these days. A cousin was quoted 20K for a Toyota EGR valve.
I'm confident the new MR20DD will be more frugal on fuel than the old QR20DE (2.0L). Everything points to better FC: higher compression ratio, direct injection vs multipoint injection, more efficient CVT, more aerodynamic body.
What I'd like to know is if this new X-trail's QR25DE has the same changes made to it as the 2014 US Rogue. We know the compression ratio is higher, but not much info on other changes that they may have made (or not) to the cylinder head, intake, etc. What the 2.5 has going for it in the FC department is the higher compression ratio, more efficient CVT and aerodynamics. So it will probably do a little better (at least) than the older gen X-trail.
I hope in the future Nissan at least changes the name or at least update the names of their engines when they change something! So consumers will at least know if there were improvements made or not. Currently they use the same old engine codes for updated engines.
November 11th, 2014 07:36 AM #179
According to Indenesian websites
The engine is new and code name is QR25DE-K2 Twin-CVTC or Dual-CVTC.
I still can't verify if its a dual injector engine.Last edited by StockEngine; November 11th, 2014 at 07:50 AM.
- Jul 2008
- 754
November 11th, 2014 07:46 PM #1806km/L is normal for any 2L engine nowadays. I get 6.3km/L with my 1st gen Xtrail in pure city driving with mix heavy traffic. I should be able to get 6.8km/L with the new Xtrail as my foot is already Eco mode by default.
They should have used the Serena engine with start stop in the 4x4 version. I think it's QR25DD. The QR25DE is getting outdated already.
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
