Results 1 to 5 of 5
- Oct 2006
- 32
February 1st, 2007 02:23 PM #1anybody hir could help me, i want to tune up my motorcycle susuki raider 110, can some one give me guidelines or tips how to do it,
thank you so much guys...
- Oct 2006
- 32
- Jan 2010
- 1
January 19th, 2010 11:36 AM #3Renfox, did you found what you want to know? I have the same problem with my suzuki shogun r 125. Can you help me and reply my blog. Thank you.
January 19th, 2010 11:59 AM #4
madali lang pareho yan. kaso not much for the raider 110cc. you should have bought the 150cc with clutch. or the 125.
anyways, panung tune up ba gusto niyo sir? tune up? or set up?
kung set-up, physical ba or internaL? dame din kaseng set up sa motor eh.
January 19th, 2010 12:01 PM #5
Tune up Suzuki Raider :
1. Change oil . Any 4T motorcycle oil tools needed Wrench size depend on the drain plug . 1000Km to 1500 km interval of oil change or read your motorcycle manual.
2. Change spark plug
3 Adjust the air fuel mixture of the carburator.
How , Run the motorcycle in a normal temperature
set the idling to a low then adjust the air by using screw driver to reach the higher idling . This give the motorcycle a good acceleration response.
thats all you need to tune up your raider .
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
