Page 826 of 939 FirstFirst ... 726776816822823824825826827828829830836876926 ... LastLast
Results 8,251 to 8,260 of 9388
    #8251
    Quote Originally Posted by Pinoy Discus View Post
    Hi Sir Pink Floyd,
    I own a Sedona Red and based on my experience okay naman siya sa maintenance. Of course since it's darker in color, mas mabilis makita yung dumi but regular cleaning is not that difficult naman. I would highly recommend the Ziebart Diamond Gloss for the Sedona Red color or any other dark color for that matter. Have it done immediately after receipt of the unit para spotless pa siya.
    Medyo pricey at around 9K for the initial application and 50% every year thereafter but sulit naman. Sa akin, water lang and then wipe down, parang parating naka-wax...
    Hope this helps!
    P4500 per year. I will buy good car wax brand na lang and the result is the same naman. What brand of car wax is the best for monty?
    Aug 2008
    #8252
    i prefer soft99... made in japan eto..
    mas matagal bago mawala yung wax.. even after many car wash...
    andiyan padin yung wax.. and.. maganda eto sa ulan..
    after umulan.. buhusan mo lang ng water.. matatangal mga dumi..
    Aug 2008
    #8253
    by the way guys.. minsan pag start ko engine..
    parang may tumatama sa chassis ko.. puwede ko ba pabayaan yun??
    or dapat pacheck ko na??
    Jun 2006
    #8254
    A number of fellows who posted their problems at Issues of the Montero sport thread had that problem (like easyman). They had it fixed at the dealership. engine mount ata yan or something. You definitely should have it fixed right away.
    #8255
    Guys ask ko lang.. san ba mganda shop mag pa detail? advisable na ba na ipa detail yung 3 week old Monty ko?
    Aug 2008
    #8256
    Quote Originally Posted by N T Y c E View Post
    no i have nothing to say!
    *aldrich, pls describe exactly and more specifically what you feel when you hit holes? You might mean it differently from some of us? For example, bilstein shocks are stiffer than stock shocks. Its meant to give a smoother ride. Stock shocks feel soft, and you feel like your fall into every bump in the road.
    want ko sana mas smooth ang ride.. yung tuwing mahulog ako sa hump..
    hindi yung ramdam na ramdam mo.. yung parang sa starex and alterra..
    anu po suggestion niyo?? and how much magagastos ko??
    #8257
    Quote Originally Posted by perfectoy View Post
    Montero Sport vs. Rottweiler
    Share ko lang my experience. My Montero was disabled by my Rottweiler. Apparently, the brake hose of the montero is exposed. Rear Left side. You should see that hose. The dog chewed the mudguard and the Brake hose. This drained the brake fluid. When you start the Montero there is an alarm in the dashboard instrument panel and when you step on the brake, you have to depress it very deep. I had to drive to the casa very slowly using my handbrake even after refilling the break fluid as there is very little grip on the brakes. Is there a way to protect this exposed hose? Imagine someone just cutting or biting this hose and this could lead to accidents.
    There is a way. Change the standard rubber brake hoses to aftermarket steel braided ones. But i dont think it can still withstand your rottweiler's teeth.
    Or fabricate a cover that while hide the brake hose.
    Lahat naman ng kotse ganyan. IMO. Brake hose is exposed. Rubber is there to provide flexibility for the suspension movement.
    #8258
    Quote Originally Posted by PLeaSe View Post
    Originally, I reserved for a silver colored monty. after a month of waiting, my SA called up and asked if i am willing to settle for a garnet green micca. I went to the casa and made a comparo between the garnet green and silver monty on display. I finally settled for the garnet green monty and I have no regrets. The color seems to turn darker when in a dark place or during night time and the garnet green color comes alive when in a bright lit place or during daytime.
    My only regret is that my unit did not escape the wrath of Ondoy and it's still at the casa for nearly 3 months now.
    Pareho pala tayo. Mag 3 months na din ung Monty namin sa casa. Sana lumabas na siya before Xmas.
    May 2008
    #8259
    mga sir meron na po ba 2010 montero balak kc namin kumuha before Christmas! o
    by jan. ano po kaya nabago.
    Oct 2009
    #8260
    Thanks for the Info benchph1. Still badtrip regarding the incident. It seems the brake hose is not a common part that they stock. The montero will be stuck in the casa for a few days until they get the order for the replacement hose. Ill post how much it cost me when I get billed.
